What did you do to your Mitsubishi today?
DSouth
Changed front and rear axle oil
- Man the rear was dark brown/black, maybe original 170k mile fluid?
Changed transfer case oil
Changed Engine Oil + Filter
Found disconnected vacuum hose and re-connected.
Clem
Last weekend I used this
To get here
To do a little bit of this
rgNtC5pNWVtV_ZJ81DHdEtd1tEcqcYHPGTYNbi9gDcunmUmE5LYBprmqiyD29h6gh9JUORSVibIKWsO3wGpFpINCTAuCzORnJBbx42dvzUxkpQm0KL9M4AVZl8J7tfykTrfHDvSlPoMRPaFku_JdXY310MTyvFLJfPtNmYlmFpVCkrcckmbZvc3uFfg8FyJf69X945-o6rYmmobHVlNvwi1pghwLXlgtAwgfc_kDO4rA3gO4mgzEWXM6lTrJenwKAunWEktdpQXo3KUbLoDCYZQEcaiJj3R-vIh3n40-HkHNSF5ffj3BAsWVoAU9kpYWxNpt6Oqwpa4AeqUJxIJ-l6Omfd8I8GxaWFdGO0yiSOPGQi7n2viBpN_jq4khTC4hxcLl7eqV_ExRhVhmKvNl9t_-FKeFppvmyeM8zeuh4xw_xGDRDUFn_QPN8dk_JfUHiINbOsR3xavmjDHdfsP7qAHSKoWaNhOL86demld-jhVv_Q2R6_Q2eh8AaxfEnB4CKo49x0IC9YmLLDLKqA6kxYPa81aD6iPFvZ_8COCtbJkgDl9EHNdi0hOGKUZFGmt2X570C05y1raT3OLHz6lkNrBBqKuH8rlfc_nyg7MGf85h52q0=w1760-h989-no
For views like this
zE6DhTaYBKGcvwao7GWIKds-c0BOQyQeLF8DpapFtQn1NMxwwPjf_5RVW5l6dlTa4oVxrwjB5GSSorDK2ozdBU6fKCQBAn_6z_0scz9qIcPylj7IjGM837jFsHAvWw5llO8RCSX5lGzjhQR451Cxw2Nk0CGil3ZH5rLrvVhMyoUScNI9mcxvm_H_u0r_0bpj7PvYyonuOrhDLTcv6RoUxrR999zGRlsP1ZOX6wbm19DSbTzaEMj3et9DqO90hcf5-roNFQK5Nf4xHsJhSqhBEcA_NorgDmnJtloYA7XzMHw5ZLdYXhUXlX46iozZGuPkPy3-2CyT1Ou2oJEuKxEMD3ov0_rnDbc4CxrMIOf9v_zS2jrYPjxUqoFuqc6GmoEn7bsWJp-MuJm3LJ943LdN-orxxBDZjQXTjvVUNZdGexhdPY0uW_I7gLAGUytVc5NSHixKleseo-IdjlVd0ZvRiP5z1FyZAFVfZA_Rfd5KWGJohMi4Ame9BR6Z_04-TAbk1EjLwf5jMceZ-6fk65lW-ATEk7Zo-5dvJor8dcfcyYsfFSOtCSxLgMOIq-VbSosk4-4DxljBq8zAFXizSRuCsTvCh3oOzJhbqikbAiLtjCnVmkam=w1760-h989-no
And this
8CeDC9GMfVdHUwDAQMe3wM-EYte7FkU0ippwS-uvwmV4tMAEN-nfqc0a2bFrxotaZVH5BnNjmamsDGT8a4Jy7OO2151ZwAACyKTTinP16T1iB262GMOigpYGxX8xyTCzDrlCmoJEfznyqV2ljEpuA8A2I2-E4Pc1V5AaRJrL2EP-GLE_pcZfVZrU-lNvse89GEDO7HoqC8rdxwKjTMfKSs3EEEWDm-oYURz2qkhHqsVwhQH1pmyUUYpN8C3BjKzanUnB85m9Jcdjs20BuXBUj6TL3VERtlZ5CCcW0thpbi78g3ogOWJCF-xxL1lnQywbMHRhys49oPnPDWRDHU2P00O47Zityraoulx1JraUFjxj2QHXD4pN-8XDXxKIIyPKm-YDzpQUycbvWWE0X2smP1gx1iDeblHVV6hLs4EtCbcwkg4CCdarm4-R3jT2g8VoXYyGS6cyvkmqXMh52KmcQ8iIB1fRxR0WtozyMndN3sBMe3_m0PRmrH_JvVV9StxPjqcbHldj9ANSW58G9GgnKXM0ToSt5eGmKJkiLq1VoNvKORmd-xMxIVilJ_x9B75_nsc6vLCFrVSTKhrqjZDr4Ri0dEenamWA8QtyiyHCZUTxiAdT=w1760-h989-no
Makin' memories
MCpxvgOeRReYhRfCmCbTG3z6g1ZtqpRc0LLQ5r7gZGGFTR0CMIefkGmuW6ee4JzS10ENWpBTT8Wd0ZW71nGIP96oSV5M9C7BSW19BYcPWl0x7N7XDgVlcrCWfK9XS_-1P0BL5dkZlssgrjHkqsmN72nQ1KNYZleAQJZZJIahUiy-b1K3386soLHaOEXB357Tsj0jZcJBRE7DuDvalE4_n8wXBhC_wwsA30DMKZ0thV-r6U4A8Rs8FvKoV8eknLsYkWGvfTLoR_fW8P9ajbPsxLaqri6Kukb4kcErAVYoDEH78ywSUnpOGCpTD3sz4uWMnW9lKYRTJIylq7Zg0VD8tdti_3mi83zHMIQZHVRKo1967ap16R8uazwwKu8ASqfCRuX2FNuqQbFw4n9PxCW8iL9Jy5hjT8D0pDcdGyD4eOrK7rsPUL8E4brvqcloFCxZArDYopw4yUJGS8CEiYFMvjqUeqM3_QetVbreJIq3GDoNDn3TYM5UBexBXvud345S_NrBHlVeGbEzcg7hhVhSkZfXzHDuKXVX2WJQs3wP4c2pU1o_Q8pP2cFaiSD3GukvtuejwqM_rlu6ttW0Vp3zKe3NskE03lDHBkdu7Nzq2zx_U_FR=w1760-h989-no
Hope you all had a good Labor Day, too!
Clem
P.S. Can't figure out how to make the pictures smaller, hmm.
Offroadmuch
Got all fluids changed and upgraded to all-synthetic: engine, front and rear diff, transfer case. All Amsoil, local dealer nearby. Previous maintenance records are missing so I only know a little about work based on some investigative work. I know I have a new timing belt. The front diff oil was very clean when it was drained today so that was done but I am glad to know everything is new as of today. I will do the transmission flush and fill at a local shop that knows Monteros and will use 100% Mitsu transmission fluid.
TheMole
Good stuff here. Mind sharing the name of the local shop that knows Monteros? Would like to bookmark it in case I need some work done.
99Montero
Waxed it and got update yesterday that my 3.15 T-case gears are almost done and I'll be shipped out soon! 😎
miloe79
Put in a new PCV valve, changed my oil to 10w30 and added Lucas stabilizer. Going to see if that slows down the oil consumption before looking into the valve stem seals.
So, any updates? Did the Lucas stabilizer worked, did it slowed down the oil consumption?
Sent from my SAMSUNG-SM-G870A using Tapatalk
SD_Montero
Driving from a job, going left at speed...35mph. Getting a kinda rhythmic slight thumping from the left side. I just did new front axles wheel bearings and rotors...and ball joints...any ideas what might be happening from anyone personal experience? Could I just be a bad cv joint?
SD_Montero
Your right. Was in a hurry on one side when I doing the work. Lug uts finally decided to practically fall off....could've died
jordanP13
