What did you do to your Mitsubishi today?
Put a rock slider on, welded this bad boy.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Did an engine flush with BG EPR.
Changed oil. Used Mobil 1 High Mileage 5W30 and a Wix filter.
Added BG MOA. oil treatment.
A few days ago I did the BG 44K fuel treatment.
Recently transfered my DIY awning to the Montero. I will be making a similar one to go over the rear opening/rear door fold down table.
Hi Hoots, do you have some details of the brackets? How long is the platform? Does it rest just in these brackets?
Thanks
G
Sleep platform when extended is 75". It's a trifold design that i copied from another forum member SONICMASD
But instead of bolting the crossbars to the frame I cut knotches into the frame bars and put stoppers on the inside of the crossbars to minimize lateral movement. That way I can remove the crossbars anytime to free up more cargo space if needed
Here it is fully extended
That rear awning should be done by Monday. Leaving for Florida to teach at an event on Tuesday.
I am also buying some Outdura awning material and will be sewing that up and replacing the tarps. I also will be making a corner piece that goes between these two awnings that will provide the option for 270 degree coverage, in addition to either or both individual awnings.
All of this will be for way less than a foxwing, for example.
Wolfbox
