I installed the lights today at work. The whole process took a bit over an hour. When we ordered our vehicles we ordered an extra switch box with the wires pre-run to the front & back of the vehicle just for items such as these. This meant the hard wiring was already done (running wires from inside cab to outside body area). All I had to do was attach a positive + neg to each light....and done. I already had the holes aligned from the red/blue light bar mounted on the bottom of my grill guard. I used the original holes from the light bar plus a 2nd set of holes with the supplied hardware for extra secure mounting. The supplied hardware is BEEFY. The mounting bolt is 3/4 in size!! I was impressed.
Last night I made a make-shift paint booth in my shop room and painted my mounts back (they came as bare metal). This was done because I wasn't sure if they were aluminum or steel. The magnet I had reacted to the brackets just barely...and only on the welds. I also noticed a small spot of corrosion on the weld (pin-head size). I decided to err on the side of caution and throw on a layer of paint (flat black enamel) to protect the metal. Also it better matches my truck.
I will go out and snap some night shots + video this evening. I will post up sometime this week. These lights are BRIGHT in daylight. I can't wait to see how they fair at night.
My truck makes a good test-bed for lights, being a patrol unit we see all kinds of road types (only a few roads in my county are paved) to include corrugations, dirt, mud, snow, sand, etc. combined with very heavy duty use. I will report back soon
Pics after install:
I had been wanting a set of these for quite some time. This was the video that made my bite the bullet and place my order:
https://www.youtube.com/watch?v=Djf1f-SB3NE
