RSC..........help
ujoint
Supporting Sponsor
You don't unless you want annoying chimes and lights greeting you every time you drive it.
FordGuy1
Call Action vans in San Clemente, They have a Fix.
Action Van Suspension
1027 Calle Trepadora, Suite 1
San Clemente, CA 92673
(949) 361-6508 ~~ Toll Free (888) 361-6508
mgmetalworks
I'm in the process of reconfiguring my van to eliminate the Advancetrac/RSC. Not cheap and it is not a simple weekend project.
mgmetalworks
A "fix"? You mean they re-did the math behind the algorithms and came up with all new parameters for off-road vans then reprogrammed the ABS module? That's the only "fix" there could be. Anything else would be a workaround or bypass of some sort.
FordGuy1
In the past I sent several Vans to Action Vans to fix the RSC issue, it was fairly inexpensive, and only took an hour or two.
mgmetalworks
I'm completely eliminating the system. All of the related components.
What is the issue you're having with RSC anyway? Were the vans all 2wd vans that you took over there?
FordGuy1
The ABS in the vans work great. The issue is when you lift the van, or larger tires, it screws up the calibration of the yaw sensor, thinking the vans is getting a little tipsy, so it activates the RSC. I believe the fix Action vans use is eliminating the steering wheel angle sensor so the RSC works in ABS, but wont activate from the Yaw sensor input.
silvrzuki77
explorer
I had RSC issues in my van after lifting it with a Ujoint kit. Chris told me to call 5star tuning. Ended up getting a tow tune and it fixed my RSC issues on the van.
crostopher
