2017 Chevy Colorado ZR2
Err
Haha, this thread is off the rails with brand loyalty wars and manual vs automatic wars!!!
Funny stuff.
Back to this truck. I'm not in the market and I'm about as brand agnostic as they come. I like what I see. I had an '09 H3T right before Hummer went belly up. I kinda see the ZR2 as the much improved second coming of that truck. The H3T had the same basic layout, to it's credit, it did offer a 5 spd MT. On the other hand the H3T was under powered, certainly no diesel option, and had a low-end highway queen suspension setup. The ZR2 seems to bring back all the goodies and pair it with a much getter engine and suspension system.
Note on the suspension. In the world of dampers spool valves are the top tier of the valving systems. Most of your so-called fancy shocks that most of us would upgrade to use poppet style valves which, while great, are not at the same level as spool valves. The Multimatics may or may not prove be reliable or valved correctly but this is a big step up from your basic Fox and King offerings. Bust out your Google-foo and do a little reading. You'll see that even the shocks on the venerable Raptor pale in comparison to this technology.
Also note the towing and payload reductions are simply the result of tuning the rear spring and damper rates for compliance offroad based on an unloaded or lightly loaded bed. This is the same as with the Raptors and there's nothing stopping you from tweaking the suspension setup to your desired load. It's really no big deal guys.
I do wonder how great the small diesel will be. I've had a couple modern diesels and so far the torque is cool but they have been consistently more expensive and less reliable than their gasser counter parts. This ain't no 4BT/6BT (for better or worse) and time will tell whether it's really all that great or not.
RF2200
I think GM (or any other auto manuf) knows a thing or two about tire sizing. They didn't miss the ball. They know enthusiasts like to tinker and mod their trucks. Smaller tires won't be a deal breaker for the majority of the market audience. Dare I say there will be zero sale-fails due to the stock tire size?
Not so. The determining factor for tire size in vehicles like this is not engineering but government regulations for things like bumper height compatibility, fuel economy and crash test standards. Towing standards and payload are also affected when tire size changes. Look at the Ram Power Wagon. You can fit 37" tires on that truck in stock form. I have 37" KO2 tires on my stock 2015 Laramie PW. Talk to a RAM engineer and they will say that the PW should ship with the 315/70R17 Duratrac, not the 285/70R17 that it ships with. Why does it ship with the smaller tire tire? Because if it had the 35s it would not be in compliance with maximum rear bumper height regulations and other government regulations. And it would not cleanly fit in the spare tire space under the bed, but the real deal killer was the government regulations.
Gone are the days when manufacturers that vehicles were built to meet a NEED. They are now simply built to meet a REGULATION.
The correct tires are the most important thing about a vehicle like this. More important than fancy dampers.
RF2200
Thought of the H3T with Adventure package as well when I saw this truck.
Modern diesel engines are marvels of engineering, but the finicky emissions systems really let them down. The best option would be something like the Cummins 2.8L Ethos engine which runs on Ethanol with the duty cycle of the diesel but requires none of the emissions equipment, has more power per unit of displacement, and costs less per mile to operate. 250 HP and 450 FT/LB out of 2.8L with the duty cycle of a commercial diesel engine is impressive. The 6.7L Cummins with that duty cycle only makes 600 FT/LB. http://www.dieselprogress.com/July-2014/A-Cummins-Gasoline-Engine/#.WC9YSGWPnzI
Clutch
<---Pass
Yeah it is a play truck...I don't think anyone is saying it isn't, other than it would be nice to have one specced that you can actually load up and use. Seems like a waste of that diesel engine.
Time will tell, do think it is funny that people will turn their nose up at the Ram diesel, but not the Chevy...which is basically the same engine.
RF2200
p nut
butter
Right. So how is it they missed the ball? Why spec it with bigger tires that skirts the line on regulation and ends up costing them (or the customer) more?
_
Also, "Correct tires" can be so many different things, especially to enthusiasts. (i.e. I do not want Duratracs on my trucks. I'd sell them first thing. I'd rather have the cost of the truck be less and fitted with smaller p-rated tires).
RF2200
_
Because people don't want a truck with lockers front and rear with 31" tires. It is not what sells. The G-Wagen has that setup and off-roaders bemoan that setup. No one is going to buy a $45,000 truck with lockers front and rear with p-rated tires. The Rubicon comes with 32" tires and almost everyone throws them away in favor of larger tires. Show me one Jeep Rubicon with P-rated tires.
rkj__
Those 32" Rubicon take-offs would be a good fit for the Colorado. To fit bigger than a 32" tire on a Z71, you either need a 5" lift, or to hack away at the rear of the front wheel wells pretty aggressively.
p nut
butter
Again, it's not a deal killer. You yourself went bigger 37" tires on your PW. Almost everyone will have their different tastes. So why equip a truck with a specific tire that a good portion will swap out anyway? Do you have any data that support sale-fails on a Rubicon or "X" vehicle because of OE tires?? Do you really think people that want a mid-size diesel truck with front and rear lockers will put their wallets back in their pockets because of tires? That's silly. :)
_
G wagens are a different category. How many do you know that buys a $100k car to off-road? Not too many, I'd wager. Hardcore offroaders isn't their target market.
RF2200
But you don't on the Jeep. You guys are forgetting that Jeep is coming out with a pickup next year that will compete directly with this. It is going to have a diesel. Going to have lockers. And is going to be able to fit at least 33" tires with no modification. This is why they missed the ball.
DaveInDenver
Middle Income Semi-Redneck
The 80 series Land Cruiser had 31" (275/70R16) SL-rated tires with the optional FR and RR lockers. I don't think anyone really bemoans the G-wagen or the Cruiser, they are excellent starting points. I like that Chevy put a legitimate tire in a perfectly useable size tire on the truck. I only run a 32" tire on my truck, I wasn't looking to fill the wheel well to the point of rubbing or not leaving room for chains. Not everyone wants to build a monster truck for rock crawling. I'm not a fan of the Duratrac but I wouldn't have a problem running it until one failed.
calicamper
c'mon...it is a truck, an offroad truck at that...these manufactures need to step it up and make an interior you can hose out, where's the water proof marine grade gauges, uh!!?? Instead you get heated steering wheels for soft handed desk jockeys...
OCD car people have ruined trucks... :D
Your right its a truck. A 40k midsized upper trim SLT needs to sport interior materials at least on par with 30k Subarus. The Canyon slt seats look far better than the Colorado Z 1 seats. But they lack very basic touches that Ford will no doubt put in the Ranger. GM has a 3yr jump on Ford. Simply pointing out the easy stuff GM can address that would make it easier to gain market share.
I dont care if its a truck, a 40k mid sized anything today there are a few basics buyers expect.
MonteroNerd
