UJOR Build Thread
philos
We mixed it up on this one since the front axle is running the RSC upgrade. So, 17x9 front wheels with 295/70/17s. Rear wheels are the stock 16" with 255/85s.
I'm assuming those tire sizes match up for height, and will be safe for the transfer case?
DzlToy
^^ less than a quarter of an inch difference in the diameter of those two tires - well within tolerance, which is usually plus or minus 3%.
ujoint
Supporting Sponsor
According to the Toyo website they're exactly the same size. 33.5"
Knowing is half the battle... danke.
For sure!
Family-van
Very nice if you have the body off!
Actually I think you can use this with the body on. I took a few other shots of the drill and base to show that it could be used with the body on. Not trying to push an agenda or sell these as don't sell these. Something I found that was neat. I like the idea about the step drills as well. Just wanting to contribute. Thanks for all the help from everyone.
ujoint
Supporting Sponsor
Bus tear down!
Corneilius
OMG shut up and take my money, where did you get that
Edit, found it. Great idea. We can modify/duplicate that main arm to make it spring-hanger specific if it doesn't clear the radiator for whatever reason
ujoint
Supporting Sponsor
RV swung by for a brake upgrade that we couldn't do when it was initially built, stops much better!
Not common that we have 2 here at the same time, my class C fever is strong these days!
Joseph McCormack
