Ski Bum Truck V2.0, F450 Rough Road RV
java
Well its been settled, 2/0 for the main house to starting battery runs, I happened to find a roll of 2/0 tinned wire on CL :wings:
java
Awesome! Windows do make a world of difference. Less bunker vibe, more "go-explore-the-world" mood.
Most definitely. I've got one more to go in. Insulation is scheduled for Monday so I have a lot of stuff to get done before then!
east_tn_81
Are you worried about the strength of the cab? I would think the removal of the window and cutting the bottom of the cab would weaken the cabs strength. By the way nice work I really like this project.
java
No not really, its pretty common for the backs to be cut out in box truck applications. The Structure at the top, the factory pinch weld for the window, and the structure along the floor is still there. I just removed the bit between them. I definitely would not use the center seat however. The reinforcement it was attached to in the center of the cab wall is gone. The aluminum I used for the window panels has a large rib in it, that helped stiffen he back wall back up considerably.
hobietony
Just for clarity, here is the wall section. I am taking about filling the hollow area.
my $.02, filling the cavity will do nothing, the conduction path is through the metal itself. If you fill with anyting, use the Skittles option. In my ambo, I didn't use the 3/4 furring you did, and in really cold weather I get frost buildup on the screw heads/path of the aluminum, as well as on the exposed aluminum framing at the doors. I'd say furr with the 3/4 ply, and try to make sure the screws you use for the finish dont penetrate into the aluminum
java
Thanks, that was my kinda uneducated conclusion as well. The interior will just be glued and pin nailed to the furring strips.
Sent from my SM-G900T using Tapatalk
java
Long list before insulation.... Got a little more done last night.
Reinforced the large window. It was a little floppy, and I didn't wan the spray foam to hold it crooked. Used a piece of oak there.
java
List, done. Way more of a thrash than I was expecting. All the little stuff adds up...
All the furring s done, all the wires wrapped, taped, glued in place.
All the tools that were in the truck are now in a pile.... in the garage.... I need to do some cleaning!! A 4800W heater heats this truck quite nice with no windows or insulation! :)D)
java
Annnnd Done!!!
Now a Question: Has anyone seen or extended themselves the exhaust/intake for a furnace? They all are designed for 2" wall thickness. Ideally I would install it in a spot that I need ~12" from exterior to heater.
I realize this is far longer than the OE designed, and exhaust temps need to stay up for proper flow, but it would be great to be able to do this..... Welding a stainless extension on is no issue.
