Meet the Trot'n Turtle - Unimog U1300L Build
Hodakaguy
Time to get the push bar finished up. First up we need to lay out the proper angle on the tubing so we can make the final cuts so the push bar will sit at the correct angle on the base plates. The cuts we made yesterday were 90 deg cuts and we don't know what angle we need as of yet. My father had an awesome trick for laying out the perfect cut lines on each side. We placed the bar in the correct location on the base plates and leveled it, then tilted the bar until we liked the angle. At that point we found a small spacer that was just high enough to clear the gap at the back side of the tubing. We then cut down a marking pen and used it on top of the spacer to slide it around the base plates and mark out the perfect cut line onto the tubing, with this method there is no guessing and both sides will be right on the money!
Push bar leveled and the correct angle set. Cut lines marked.
Nice flush fit.
Dad performing his magic!, he's an artist with a TIG torch.
Installing the 20" Baja Designs light bar. We drilled holes for the bolts to recess into the push bar then welded half nuts onto the bottom of the bar. The light mounts will now bolt directly to the under side of the push bar. The mounts are set back slightly so that the push bar sticks out past the light bar for protection.
Light mounted up to the push bar.
Push bar angle
The light bar has a solid driving light pattern to compliment the spot beams higher up on the truck. The bolts holding the push bar to the bumper are the same size as the OEM bolts that are holding the bumper to the truck but have smaller round heads.
More to come...
Hodakaguy
patoz
Your Dad's welding bead looks like a row of nickles. Absolute perfection!
The marker and spacer trick is the same technique I've used to mark the back-splash of kitchen counter tops to make them fit the irregularities of sheet rock walls.
Who makes that light bar, if you don't mind me asking? I haven't seen the connected reflectors shaped like that before. A lot of brands use the overlapping reflectors, which I don't like, but that one you have is pretty cool looking.
Hodakaguy
The lights are Baja Designs ONX6 units, they aren't the cheapest but they are the best. The light output and reflectors are top notch plus I like the daylight color spectrum as it's easier on the eyes.
Hodakaguy
Wyuna
i have to agree with the others, that TIG weld job on the Nudge bar is fantastic, great skill set.
As for the marking out with the packer, I'm a cabinetmaker by trade and its also great for panel fitment to get the vertical alignment as well.
patoz
Hodakaguy
Nice stuff but you're right, not cheap at all...!
Hodakaguy
Thanks guys, my father is a retired welder and very good at what he does. Some of his stainless work is simply amazing!
Hodakaguy
Hodakaguy
Time to remove the deck on the bed in preparation for paint. The bolts holding the wood onto the frame are flat topped and have a square shank under the head to keep the bolt from turning, unfortunately after years on being installed in the bed the bolts are rusty and about half of them just spin when trying to remove the nut. Time to break out the Mig.
Bolt installed in the bed, this is one that's spinning.
We tacked a piece of round stock to the head of the bolt so we could hold it and keep it from spinning, once out we just snapped the rod off the head and used the same rod to weld onto the next bolt. We had a hand full of rods going as we removed all the offending bolts.
More bolts on the way out
Underside of the bed.
Bed coming apart
The wood is in good cond, we will sand, re-finish and re-install.
Removing the metal hardware, these bits will be powder coated.
Deck removed, frame is nice and clean underneath. We will soon pull the frame and paint the underside black, the sides and gates will be painted the same color as the body.
Top view of the winch.
Starting to strip down the interior for paint. Lots of small bits to remove.
Inside of the doors have a thick coating of cavity wax for corrosion protection, they are very clean with no rust.
While I was working on the interior my Father (Danny) was busy cutting out the plates to fill in the corner gaps on the rear fenders.
More to come....
Hodakaguy
Wyuna
But i like the RED,
you will notice that the Unimog will be slower after u paint it in a colour other than red :coffeedrink:
iStan814
