Monteros on craigslist
KarmannMarco
After I did my timing belt/WP/seals etc... my oil cooler lines sprang a leak. Or maybe they did the timing belts but skipped the cam/crank seals?
Tundraguy81
This Montero is right down the road from me. I looked at it before I got mine but the guy didn't want to sell it at that moment.its really clean inside. He claimed all the maintenance including a timing job was done. You can tell it was in an accident in the front bumper area. When you pop the hood you can notice some of the factory clips are replaced by zip ties. But over all it's pretty decent shape.
https://richmond.craigslist.org/cto/6067900781.html
bugeyetex
"... Recently Replaced:
New Timing Belt, water pump, new tires, new shocks all corners, new battery, new oil change.
A light oil leak, Radio not working need code, no driver side visor..."
They put all of that work into it, and still come away with an oil leak... WTH?
Might be a rear main...
Sent from my SM-G930T using Tapatalk
PNWav
