Is it possible to match the tops of the front and rear fenders?  I think it would visually look better with a consistent line along the top.  Also, it would make them higher clearance for the stuffed-big-tire-flexy crowd.
I could change the height of the top of the rear fender and move it higher, and I considered it but ruled it out for a number of reasons, including:
- The limiting factor in tire size is not this fender, it's the wheel opening in the JK body.  Moving the top of the fender higher wouldn't support tires any larger than not moving it unless body sheet metal trimming was done.
- As it is now, these fenders (front and rear) have at least the same clearance as the new MOPAR "High Top" fender flares.  What the ads I've seen say about those:
"allowing for a 35" tire without a lift , or a 37" tire with 2" of lift. Fender flares attach to the stock mounting holes without trimming the sheet metal". That statement applies equally well to these flat fenders.  35's with no lift and 37's with 2" lift seems pretty good to me (Dang it, now I have to get 35's so the wheel arches of these fenders get filled up better
- Given the default stance of the JK (slightly nose down), as they are now the distance between the top of the tire and the bottom of the fender is about the same front and back (about 6.25" on my Jeep, both front and back).  Also, as currently designed, the tops of both the front and rear flat fenders are the same distance from the ground (about 39.5" on my Jeep).  Raising the top of the rear fender would make the distance between the tire and the fender larger in the back than in the front, and place the top of the rear fender further from the ground than the top of the front fender, both together would probably would look strange - in combination with the default rake, increasing the distance in the back would likely make it look like a hack jack-up job was done in the back.
There are a few more less important reasons, but I think those three are the main reasons for doing the height as I've done it.
