New to me 99 Suburban: 5.7 vortec repairs
rayra
A. That the smoke appears after you let off the accelerator seems to indicate either oil or water is being drawn into a cylinder (or more than one) during the intake stroke and when there is less or negligible backpressure. Whatever is being drawn in is happening at negative manifold pressure.
B. What does that exhaust smell and taste like? Is it sweet? Does it smell / taste like burning sugar / glycol? It's white-ish, would sure seem to be coolant. But hard to really tell in your vids. I've seen bad oil ingestion problems that generate similar smokescreens. So the smell/taste is important.
A & B combined, could very well be - especially on an older high-mileage engine - worn (baked hard, cracked) valve stem seals or valve guides. The lower pressure on #4 with little change on a wet/oil test would also correlate with a valve problem. So would the smoke bloom at throttle let-off.
Not meaning to send you on a goose chase in another direction, but these are similar symptoms and should be considered and ruled out.
C. none of the plugs pictured were getting much if any coolant on them, before your rebuild. They would be much cleaner on the electrode / in-cylinder ends, much like a steam-cleaning. You might consider reinstalling those plugs and see which ones get cleaned by whatever is going on now.
D. The bubbles in the funnel mean very little. Even once the engine is 'burped' as you put it, it would generate bubbles on its own with no leaks, just as coolant boils near the combustion chamber. Put the pressure cap on and seconding the advice to borrow a coolant system pressure testing tool and see if you really have a coolant system breach. If there was a much larger air flow coming out, it would be determinative of a head or head gasket problem.
E. your numbered compressions, I don't usually see them numbered like that across a page and it actually helps in diagnosis to arrange the values the same way the pistons are arranged. As most often a head gasket failure occurs in adjacent chambers, typically 3-5 and 4-6.
That you have (surprisingly, in an old motor) very consistent compression readings across all but 1 cylinder and little change in the wet test of that cylinder would seem to indicate either a head gasket leak affecting only one cylinder or a valve / valve guide / valve seal problem or a possible head crack.
At this point and especially if that smoke cloud is sickly sweet and not just burnt smelling, I would perform a coolant system pressure test and I would consider introducing some stop leak into the system. Delco's large pellets or BAR's similar ground walnut shell product works well and it has completely stopped a head casting fracture problem on my motor. I've also successfully used Almuna-seal and Bronze-seal powdered metal products in emergencies.
It would solve two of the three possible problems / scenarios.
It's up to you whether to consider the stop leak a long term solution. It's a factory solution in the case of my CASTECH heads. It would certainly help determine that it's a head fault, re coolant getting into one or more cylinders. I would consider it as part of the diagnostic process, low / no labor one at that. And an interim solution to the problem itself. Frankly I'd put it in, do some low-engine-load local driving in it, run a few errands, re-test and maybe replace the oil if necessary and then drive it 'for real'. And make sure you have 'AAA Plus'.
eta
You've made major progress so far, even if it might not feel like it with the setbacks. Don't get discouraged. You haven't wasted your time. At a minimum you're learning new things. And at the very least you've done an otherwise good intake / fuel injection rebuild. Just need to nail down how you (seem to be) are getting coolant in the combustion (chambers)
One othe rthing I noticed in your pics, a lot of debris around the bolt holes in the heads when the intake was pulled? was that metal? some sort of thread sealant? Was their an variance in bolt lengths in the intake to head bolts and did they all go back in the same holes? There's a small possibility of over penetration of a bolt causing a crack resulting in a leak. It's possible to OVERtighten stuff too.
unabashedpraise
Exhaust smells like coolant.
I'll get a pressure test tomorrow.
I actually laughed out loud on the AAA comment!
unabashedpraise
I dont think cylinder 4 is low enough to be the problem, if I was doing this job the next step would be to pressure test the cooling system, see how bad the leak is and if you can find it! Looking at your previous posts I wonder if the cleaning you did to the intake caused a problem with the sealing edges of the intake? Generally problems that didn't exist before the job don't suddenly pop up after the job!
Could the introduction of an intake actually holding pressure affect the heads?
rayra
laugh or cry, thems the choices in life. My C-10 has come home on a flatbed more times than I can recall, over 30yrs / 350k mi, if it wasn't for AAA and my own mechanical abilities, I'd have sold it off a long long time ago. hell it's busted right now, cracked passenger side exhaust manifold. The one I scavenged from a junk yard to replace the original, that was totally blown out. I'll get around to it one of these days, along with the aforementioned valve stem seals, so I can get it to pass CA smog.
to partially answer your question to nevada, it actually could, a little. The increase in manifold vacuum from a properly installed intake could indeed increase the suction other places, drawing other things in or making an already existing problem worse / more noticeable. But I'd have to think it would be a miniscule difference, wouldn't create such a plume. But I don't really know for sure.
NevadaLover
Forking Icehole
Lost the beginning of that post somehow!
The heads of the 5.7 vortecs don't have the problems with cracking and porosity that the ls series have so I would look closely at the intake before moving on to the heads as the source of the leak!
Worst case scenario you can buy a long block 5.7 from summit for under 2 grand with warranty!
NevadaLover
Forking Icehole
That is if the heads are the problem, it would be easier to replace the engine than the heads, especially considering the mileage!
rayra
Oh that's miserable. Have ot replace the radiator and do the pressure test again, just trying to find the real problem.
I'm still suggesting putting some stop leak in it before you make any more major expense or labor efforts. Could solve both problems for $5. Maybe.
unabashedpraise
I've been looking at pics and reading around the net. I came across a video of a guy doing the intake repair. What I noticed was the difference between the two in relation to the clearance between the gasket and the coolant ports on the two diff engines. He had traditional gaskets and a failure on the rear channel at 37k miles.
His:
Mine:
Maybe this is the issue? The gaskets are in place according to the nubs the bottom.
NevadaLover
Forking Icehole
I'm not thinking so, if the sealing surfaces are true and the intake is torqued correctly, the gaskets will seal with enough force that the coolant should not be able to force its way past and create this kind of problem, maybe you are correct in looking towards the heads as the problem. maybe there was a leak before and the job had made it worse, stranger things have happened!
rayra
Personally I don't like the fitment of that dogleg in the gasket, at all. It's what prompts me to suggest adding some rtv. Or trying to find a different gasket set with better fitment. Proper torque and pattern becomes even more important with that poor fit.
NevadaLover
Forking Icehole
The original design fit piss poor like the too, haven't seen a design that fit without overlap somewhere, these gaskets are designed to be trimmed slightly as long as you stay on the thinnest part at the edge of the port but I never have and have never seen these kind of problems, maybe I've just been lucky?
unabashedpraise
I'm going to pull the intake off again. I'm going to check for warping and if that's fine I'm going to put epoxy in the holes.
If that doesn't work I'll probably just get a new intake. I've heard bad things about dorman. Maybe a Delphi or acdelco.
Also looking for a new radiator. All the code requirements per radiator a bit annoying...
