Comanche Scott
For a long time I've been sourcing parts and planning to do what I've been calling the "Retro Rhino" grille kit for the JK. Styled like the old Gladiator "Rhino" front end, this would be a bolt-on set of parts to backdate the styling of the JK to the Gladiator "Rhino" look. I've written about it from time to time in this thread.
Now that the flat fender project and a few other projects are done, I've finally got some time to work on the Retro Rhino project. I'm doing a scaled-down version that will use the stock JK fenders, so the front panel will be slightly narrower than the JK grille. The original FSJ front hood and panel are about 70" wide (roughly 10" wider than the JK tub), so scaling is very necessary which makes some of the original components way too big, so I've sourced scaled down and updated components.
This next photo shows the components I will be using - original JK headlights, scaled-down turn signals, a scaled-down Jeep grille emblem, and modernized/scaled "pie plates" (these are actual grilles with openings rather than being solid like the originals).
The drawing the components are sitting on shows the scaled-down front panel width compared to the red JK hood at the top of the photo - the panel is a bit narrower than the JK grille.
There will be 3 fiberglass components for this kit - a hood, a grille panel, and a center grille. The reason the center grille will be molded separately from the grille panel is so that it can easily be finished differently - chrome plated perhaps. The first component I'm working on is the hood.
I'm making the hood by splicing parts of an original FSJ hood together with a JK hood. The result will be a hood that bolts up perfectly to the JK and matches the curves of the side of the JK but has the raised center section and front profile of the FSJ hood. The first step is to narrow the FSJ hood so that the raised center section will be the correct width for the scaled-down grille. I'm taking 9" out of the center. In the first photo the 9" to be removed is marked; in the lower photo the hood has been narrowed and welded back together.
I also needed to narrow it on each side of the raised section in the center, and since the FSJ hood will be spliced into the JK hood, a lot of the FSJ hood won't be needed, so I cut most of it away. In the next two photos, the narrowed/cut FSJ hood is sitting on top of the JK hood. You can see the weld seams from additional narrowing I've done on each side. The lines of the JK hood and the sectioned FSJ hood are starting to flow together pretty nicely.
This is very much a background project, so I won't be posting regular updates.
Pretty awesome to see you making progress on this! Even if it is just a background project, it is still a very cool background project.
