Lets see some full size pictures...
Mojavejohn
where were you hunting, It doesn't open up in Ca. for another few days?
From last weekend quail hunting
JPR4LFE
Exploring in the trees with the Power Wagon, and found some fresh snow at higher elevations. I had to break out the buffing wheel when I got home after brushing pine needles all day :)
JPR4LFE
If pin stripes are going to bother you, I suggest getting something smaller and/or cheaper.
Ha! I still have my 97 XJ (both smaller and cheaper), but am loving the Power Wagon and it will be my primary exploring/wheeling/camping rig and will get plenty of use in the rocks, trees, mud, etc. For me its more of a "spatially challenged" jeep than a truck, but still has the ability to pull a horse trailer when needed. But even a truck that gets used still deserves a coat of wax from time to time :)
nacholibre
94 Bronco
Finally wrapped up the rear bumper and carrier...
This is my next great adventuremobile. The plans are getting worked out but right now it looks like top, doors, a little lift , a tad larger tires, a couple winches, a roll cage and a 4l80e swap and she will be perfect. The only problem is she is still in gov planet jail at Ft Polk. Most likely be another month or so before I can go get her.
leviathan907
Hello everybody, I guess its time to introduce myself! My name is Levi originally from Alaska and working on my second silverado. This is a 2004 2500HD with a 6.0 vortec, flowmaster 50 exhaust, airbags, K&N drop in air filter with the airraid MIT. Added some towing mirrors with reverse lights and bfg KO2 285 75 16r. Next step is a diablew tune that will be in the mailbox on monday, dual battery setup that I'll be starting tomorrow. Then when I have a job again I will be getting the kognito leveling kit and rebuilding my sleeping platform! Hope you all are having a great IMG_1240 (1).jpg
V45W_Proto2.5
