2004 Tundra Adventure Cab - Build/Adventure Thread
toyotech
Back in action after three months or so.
Newest mods
Manual Hubs
4.88 gears
Harrop Elocker Rear
BFG KO2 315/75R16
On Board Water Tank
Dual Pass Power Steering Cooler
26" Rear SS brake line
Front SS brake lines
sologeek
Newest mods
Manual Hubs
4.88 gears
Harrop Elocker Rear
BFG KO2 315/75R16
On Board Water Tank
Tough looking truck! Grats
PHeller
I'm always curious if the manual hubs will give better fuel efficiency or not.
Then again I'm sure the 35's make up any difference.
toyotech
I'm sure it will help with MPG. The wheel in the air can free spin so much easier now. I can tell there is laterally no resistance sliming by hand. Just rides on a brand new koyo bearing.
Plus I'm regeared to 488 it's been a pleasure to drive so far. Can hold final gear the entire time on freeway where before it would downshift on the slightest up hill.
toyotech
Why did you go with manual hubs?
More options. If I snap an axle I can unlock and not have to replace to drive.
I can run with no axles and my wheel bearings won't fall apart as the fixed cv axle is what sandwiches the bearing in place.
My cv boots will last forever as they don't ever spin at any speeds but when I'm using them at low speeds. Lifted trucks tend to put cv boots at an angle that allows them to rub which wears them out.
I can also use 4lo with front unlocked which will give me 2lo for backing up if I'm towing or if I wanna drift with much lower gearing.
Helps with MPG
toyotech
Very cool! Have you figured out the dash 4x4 light yet?
Sure did. Just need to put the gray wire on the ADD to ground and it thinks the front add is locked. I plan on putting it on a switch otherwise it will keep flashing even when I'm on 2wd
toyotech
Putting on some miles and loving the 488 gears. Had to make a cool down break for the gears at my local marlin crawler store.
toyotech
Nice LC in the background. It would be pretty fun to have a chance to nose around in their store and shop.
No store front really. Everything is kept in back or built to order. Shops pretty cool but I mainly see them working on rigs. Assuming the R&D is hidden lol.
All vehicles in front of store are employees
toyotech
Buddy sent me this photo of someone else's tundra in another city who has a similar combo lol.
toyotech
Hosting a group buy. Will be a one time discounted price on a Brute Force Fab front bumper with one pair of square led cut out and with or without hoop/side support only. The run will only be for this option only. Let me know if you would like to get one.
Winch ready
$800 no hoop
$885 with hoop/side support
Plus shipping. $75-150. Higher in Oregon. Washington. Colorado
Special pricing ends on Black Friday at midnight
PM this info email. Zip code. Phone number
Access or Double cab. Hoop or no hoop
if you like to get an invoice sent to you. Pay when ready to order
Or fill out contact info
http://www.bruteforcefab.com/contact.html
For Access Cab and Double Cab 1st gen Tundra's only
abctrash
