FOUND Vans For Sale!
zuke
Low Mileage E450 Cutaway
https://raleigh.craigslist.org/cto/d/2010-ford-e450-cab-chassis/6464395646.html
Deshet
Seem pretty decent, about the price of a 4x4 conversion, bonus you get a lw mileage ambo...
https://ambulancetrader.com/adDetails.cfm?aid=5872&cat=Type+III
Sent from my SGP511 using Tapatalk
My Mini Mod 4x4 with leaf Springs up front, Warn Hubs, and 31" Tires can be had for $15,000 if someone missed out on this one.
It came from a rural county and only has 90,000 miles on the 7.3
It is extremely clean and rust free.
Power Windows, Locks, Cruise Control, Front and Rear Heat and AC.
New Virginia Safety Inspection Sticker.
Only the stickers have been removed so far......
Deshet
Factory Built Stealth Undercover Van
Selling My Undercover Van.
2002 Ford E250 5.4
The van has 26,000 miles.
Virginia State Safety Inspection Performed by Firestone (no issues)
Everything in the Van is new
The tires are new.
Everything works as it should.
This was built as an Undercover Van.
It has room for 3 31 group batteries.
The has a lockable door between the front and rear.
The van can be started from the rear cabin. (wall mounted key switch shown in pictures)
The rear is already built and will easily make a mobile office or Camper Van
sold
eporter
Here's an interesting Astro "Ambo" that was probably just used as a wheelchair transport vehicle. Cool with the high roof and rear vent windows already added. If only it was AWD...
https://portland.craigslist.org/mlt/cto/d/94-chevy-astro-retired/6475477746.html
94 Chevy astro retired ambulance - $1800 (NE Portland)
I have a Chevy astro retired ambulance cargo van no seats in the back 6 cylinder engine automatic transmission rwd 137 k miles runs and drives as it should new alternator and battery this van is ready to go to work it came straight by the county so it's been well maintained. the height of the inside is 60 inches, Asking $1800 if you have questions TEXT 503720172six.
Bikersmurf
Jared Bybee
1995 Ford E-250 4wd Van - $14k - NC
https://asheville.craigslist.org/cto/d/1995-ford-250-4wd-van/6441084437.html
Van lived its entire life moving antique furniture all over the southeast before I got it. Has since served as my camper, exploring WNC and surrounding areas.
The van has the 4.9 inline 6 motor with 165,xxx miles.
E4od 4wd transmission.
Borg Warner 1356 electric t-case wired to the dash in working order.
Dana 50 open front w/ 4.88 gears.
Rear semi float 60, open w/ 4.88 gears.
U-Joint 4" 4wd conversion kit.
Front and rear Fox 2.0 shocks.
Front and rear Carolina Driveline driveshafts.
(5) Aluminum 16" rims w/ 285 75/16 load D BFG All Terrains.
Rear swing away tire carrier.
Bushwacker fender flares.
Lots of routine maintenance and replacement parts.
New
Radiator
Fuel pump and sending unit
Alternator
Starter
Ignition over haul (cap, rotor, wires, plugs and coil)
Interior has also been upgraded. Has had a headliner added. 2006 low mileage front seats. Has an Adrian shelf cut down into a little kitchen area. Also repurposed and salvaged an exhaust fan that's wired to a switch at the shelf. Has wooden slats added which are perfect for adding walls. Perfect blank slate for someone.
Van does have normal exterior blemishes a 20+ year old van would have. Has been down many of wooded roads. Just a couple of small dings. Rear door cables need to be replaced to open on the right side. Will come with spare unit bearings and other misc parts.
If you're not familiar with UJoint van conversions, please do some research. They are the premier van builder!
$14,000 obo
Clean and clear title!!
Call or text anytime I'll be glad to answer or help any way I can. 704-995-689one.
Keywords: fourwheel drive, four wheel drive, quigley, sprinter, syncro, vw, conversion van, camper, camp, rv, camper van,
Houie
