The evolving build
Kpack
Installing coilovers, front brake lines and diff drop this weekend. Any words of wisdom before I do surgery?
If your old hardware is corroded it could be a very rough job. If everything is clean then it really ought to be very straightforward to swap the coilovers. Mine was a nightmare because my lower shock bolts were rusted to the bushing sleeve and would not come loose no matter what. I had to cut one of them off and that took a very, very long time.
Cletus26
If you need to cut anything off Diablo carbide reciprocating saw blades are absolutely amazing
Onegen
Damn fingers crossed, we have beer on standby so I'm hoping that will help.
Onegen
Shop finished timing belt and water pump which gives me a piece of mind at 149,000 miles. Stuck at work due to impending flash flood warnings so it gives me time to look thru all these threads. Holy **** I've gone down some awesome rabbit holes and now realize there's going to be more mods to learn and do. Going to attempt the banjo bolt brake lines which will be a first for me and then the suspension this weekend. I'm looking forward to getting my hands dirty.
Onegen
SS brake lines with banjo bolt installed along with front coilovers. Fun install with minor delays. Hardest part was bottom bolt of bilstein shock. Not sure how the guy before me installed them but we needed a torch to cut the bolt. Fox was a great fit but I need to adjust ride height in anticipation of front bumper and winch. Rear shocks and diff drop next week. Also looking to do a diff breather relocation soon too
toyotech
Should really look into upgrading your brake calipers to 13wl. They are bigger and better than what you have now.
Onegen
I need to give credit to toyotech for the brake line and suspension upgrades and lhanson for the bumper upgrade. Your threads helped our tremendously. I'm only hearing good things about brute force fab and can't wait for the finished product.
SportsmanJake
Did you place an order with BFF?
Kpack
Nice work on the front end. What brake lines did you go with? That's one thing I haven't done but probably should. I'm curious as to how the Fox's perform for you as well.
Onegen
The brake lines were really easy and fun. I snapped one of the bolts off in the caliper but had an easy time taking it back out and replacing it. Here are products
xander69
