treckin
Ok I got the Rear Differential ECU today in the mail. Luckily they included 3 if the 4 connectors, so I can at least try to order the parts online (connector housings, terminals, crimp tools).
I haven’t had a chance to correlate all the wires to the diagrams I posted, I’ll get to that and then post an update.
The connectors are tycho part numbers. The 2.5mm^2 wires are the diff motor supply/return.
The ECU housing has the terminal numbers stamped on the male connector housings, so if I can’t source the housings and contacts I can at least solder, extend, and pot the unit and install Deutsch or similar parts.
Photos:
Photos:
