treckin
Hi guys,
I'm new to this forum but I wanted to make a thread here to journal some of the outfitting I've done and am planning to do to my 2012 LR4 HSE Lux.
Here's the baseline:
Vehicle purchased from a JLR dealer, 2 previous owners. 81,XXX on the odometer when I picked her up. Original purchaser declined the HD package unfortunately, but did get the 5 camera Vision Assist option, which has been pretty useful and I intend to modify. As far as I can tell the vehicle was exclusively used for commuting. There were essentially no signs of wear and tear in the interior, and only minor exterior blemishes.
So far, I took the vehicle to Frank Raines OHV park, outside Patterson, California, twice for shake-down runs.
The first time out, I discovered the/ruined the F/L LCA, rear bushing.
The second time out, I hit ~10 inches of mud pretty quickly and ruined the alternator immediately. Why the heck would you put the alternator at the bottom of the belt train on a vehicle that is specced for water crossings?? This must be unique to the NA 5.0 V8 engine accessory drive setup... Vehicle drove about 30-35 miles on the battery alone before needing a flatbed back to base.
I took her to the shop, replaced the alternator, and added the following:
Pics attached:
![0usFcqcASYadB1b5qFdukA.jpg 0usFcqcASYadB1b5qFdukA.jpg](https://expeditionportal.com/forum/data/attachments/348/348505-3bbc3707e97f1248503e01514da9e9ee.jpg)
![IMG_0390.JPG IMG_0390.JPG](https://expeditionportal.com/forum/data/attachments/348/348506-4b6d135062d0214cdd8526be8dddeb03.jpg)
![IMG_0392.JPG IMG_0392.JPG](https://expeditionportal.com/forum/data/attachments/348/348507-f236ae937e86b3500714b24555093a57.jpg)
![IMG_0393.JPG IMG_0393.JPG](https://expeditionportal.com/forum/data/attachments/348/348508-8fb0fc8137fe872cef162d490918c4a7.jpg)
![5QUD0ZNRSB2IcFBOfbCFNA.jpg 5QUD0ZNRSB2IcFBOfbCFNA.jpg](https://expeditionportal.com/forum/data/attachments/348/348509-28e9d2f134ae6b8144a29be93e350f9a.jpg)
![nuByzb4vSqG05T2q0JKOhw.jpg nuByzb4vSqG05T2q0JKOhw.jpg](https://expeditionportal.com/forum/data/attachments/348/348510-e28545f27a4005bb715e1bcf23b2b3b7.jpg)
![IMG_0400.JPG IMG_0400.JPG](https://expeditionportal.com/forum/data/attachments/348/348511-911175ee3fcee2667f31b9018f3e2edf.jpg)
![fullsizeoutput_6ec.jpeg fullsizeoutput_6ec.jpeg](https://expeditionportal.com/forum/data/attachments/348/348512-b4ffd3ff9edc9aa2875e571850c1e839.jpg)
![fullsizeoutput_6ea.jpeg fullsizeoutput_6ea.jpeg](https://expeditionportal.com/forum/data/attachments/348/348513-9299bcb021e013101c05b3d7fc108796.jpg)
![fullsizeoutput_6eb.jpeg fullsizeoutput_6eb.jpeg](https://expeditionportal.com/forum/data/attachments/348/348514-d07090df22cc914a70bde92788bec99e.jpg)
- SYA Off-Road bump stop spacer, limit straps, and lift rods.
- Polyurethane bushings for Lower Control Arms, Front and Rear Swaybars and front end links
- 32" 275/55/20 BFG KO2s, D-rated
- Using IID tool from Gap Diagnostics I lifted the truck and calibrated the air suspension. I added enough clearance to use all 3 hight selection modes: Off-Road, Normal, and Access.
- I added the digital speedometer readout to the Instrument Cluster, and adjusted the Rolling Tyre Radius field in the IC calibration to match the 32" tires (speedo reads correctly now).
- I added the Front Runner Slimline roofrack & rear ladder
- Full cabin seat covers and rubber mats
- The front lower control arm bolt guides (the metal cylinders that go inside the polybushing, through which the eccentric alignment adjustment bolt attaches to the LCA clevis, was too long and needed to be trimmed to fit inside the LCA clevis
- 32" tires fit just fine with essentially 0 modifications, only the slightest rubbing and at full right steering lock - assuming you have adjusted the suspension height correctly
- If you install the limit straps correctly, there are no issues at any suspension height
- You cannot "alt tab" on your phone while using the IID tool to calibrate the suspension
- Ignore the 465mm front and 485mm rear baseline adjustments suggested by the "guided" alignment procedure, unless you're using factory tires. Instead use 490 front, 500 rear, Otherwise you will not be able to use access mode (the vehicle will lift into extended mode when it detects a bottoming/bumpstop condition at all 4 corners, this is a product of the bumpstop spacer)
- The corners can be as much as a half centimeter off as measured from the ground to the top of the wheel arch (at 0 caster) - I tried to calibrate it out quite a few times, seems like it may just be inside the error tolerance window
- You might be tempted to try to run the suspension lower than the 490mm figure, however the dampers do not perform correctly/normally when lower than that. Its a night and day difference, give it a shot. Rebound and compression damping are really off if the vehicle is too low once the bumpstops have been shimmed
- Even with M/S rated street tires and no lift, the LR4 us a super capable wheeler. The HDC (Hill Descent Control) system is crazy powerful.
- Low range in rock crawling mode - turn off DSC or traction control as suggested in the 4x4 nav application
- Transmission shifting in "D" while in low range and rock crawl mode is painfully rough/sharp/disruptive, use the manual shift mode to stay in 2nd gear for everything but climbing and mounting
- The Vision Assist Cameras on the sideview mirrors are super useful with the "Kerb View" special view selected. You get a left/right view with your front tires in frame. The rear/bottom of the image is calibrated to precisely the front of the rear tires, so when the obstacle hits the bottom of the frame it just just touching the rear tires. The ones on the front bumper are beyond useless.
- Trust the terrain response computer, brake traction control, and center locker. Pretend its not there and drive slow and steady, the car will generally do everything else even if you take a really dumb line over an obstacle.
- The Front Runner side rails rattle like crazy and need to be manually gasketed/secured/quieted/silenced
- The alternator on the 5.0 V8 is NOT mud-proof in any way, and is mounted super low in the accessory system. Horrible design, I might try to relocate it someday.
Pics attached:
