Raul
A little update.
Interior: I decided against doing my own corners between the headliner and the wall. I am going to use the original headliner. Since my grief against it was the vents hump in the middle, I am cutting it and replacing it with a varnished plywood. The roof vent ends behind the rear seat.
Death Wobble:
After replacing the cc880s with cc880, I suffered the dreaded Death Wobble. I suspected the new spring rate and the change in ride height was a factor, but component wear could be another element so i decided to replace the tie rod ends and the drag link. No change.
I am a big fan of triangulation and when i was considering doing my own brackets vs. buying the MG kit, I always though about reaching from the track bar bracket to the other end of the frame. Since I had an useless old drag link and the brackets from the original van's suspension, I made a cross link to provide extra rigidity to the track bar bracket. This didn't fix the death wobble issue. MGs bracket is up to the task, but I do not think I am hurting anything and it may relieve some stress from the steering box area.
Caster. Caster has always being discussed on DW issues. I think that my issue was that since my van sits a little by lower than intended with the softer spring (cc880) when going through a big bump (that's when i had the problems) the suspension cycles between negative caster to zero to positive caster. This is creating the excitation that reaches the harmonic frequency to create havoc. I replaced the 0deg. bushings with 2.5 degrees and now the wobble is gone. I take the same railroad crossing next to my house that induced all the vibration and any rate of speed and the van land very stable. I'll update as I put more miles. So far so good after one day trying to shake things up.
Death Wobble:
![XWYY1618[1].jpg XWYY1618[1].jpg](https://expeditionportal.com/forum/data/attachments/363/363997-9cd3cf4745e7c4bb04a39abf572f998d.jpg)
