My Gen 2.5 Journey, a build thread.
Tjtalan
I was at the shop late last night trying to get some work done on the Monty. The front diff is installed, with all new ball joints, and axles have new boots.. I also got the compressor mounted, I deleted the cruise control and it now sits in that location.
I still need to plum and wire everything, that should get done tomorrow. Hoping to have it ready for Big Bear this weekend!
Tjtalan
First test of my TRE front locking differential. I only have the front installed at the moment.
zerodrift
Your build is really coming along! Really good to see the locker install and in action. One of these days I'll be doing the same thing to mine.
Tjtalan
Sorry for the late reply. We spent the weekend in Big Bear. Thanks, it still has a way to go, but its becoming capable. I’m very happy with the front locker, should definitely be on the list.
Tjtalan
What size are those?? Also what lift are you running?
No lift, just some turns on the torsions.
The wheels are Method 17x8, true beedlocks. Tires are a 35 equivalent. They will go on after some suspension changes.
Tjtalan
I have been dealing with a voltage drop issue. The battery, and charging system wiring was a mess. So I figured it was time to clean things up a bit.
Charging system is now perfect!
Before
After.
Tjtalan
Part numbers on these and where did you order them from?
I did not save the # after searching for it on this forum. They came from one of my wholesale vendors through my shop.
Amazon’s also has them, just search the #.
