Smittybilt Scout Trailer Reviews?
mfcoffroad
For any of the lurkers on here that want to get the scout but are not willing to wait here is an alternative: https://www.alibaba.com/product-det...l?spm=a2700.7724838.2017115.42.7b8f14d3foM40f:rolleyes:
Looks like smitty’s original supplier is mad they aren’t being used anymore and is now offering them direct to the end user. However....importing a trailer into the US is sooooooo troublesome, it’s not even worth it. The problem, when I tried doing this was a bunch of fees, customs issues, no vin, hassle with explaining there was no motor is the trailer, and the possible customs inspection that hits you for $1000 no questions asked. Then you have to worry about FOB, LTL, LTC, insurance on the water insurance at the ports.....it’s a nightmare to try and save money, and in the end you either spend the same or if more than what it costs here stateside.
Just letting you know what I ran into.
mep1811
Gentleman Adventurer
Picked up my trailer today from
@habitatoffroad.
Tows nicely behind the Porsche. 80-90 mph like it's not there.
I'll have to modify the tire carrier the clear the hitch so it opens but that's a minor thing.
Can't wait to get home tomorrow start working on it.
mep1811
I'll start working on the electrical this weekend.
I'm debating on a battery box like this. Or just using a battery hold down.
I like the battery box idea because it'll be protected from any other items and throw in the box.
What have you guys been using?
mep1811
Going to mount my Batwing on the trailer and this seems to be the best way to do it .
Has anyone else mounted the Batwing?
mep1811
From this 4 day weekend in Mexico. Just living on the beach, 30 miles away from closest population. Here is my jeep on 37's - so anyone looking to get one can see how the trailer sits with stock tires.
Trailer packed up:
View attachment 519077View attachment 519078
Trailer deployed:
View attachment 519081View attachment 519080View attachment 519082View attachment 519079
the trailer worked out amazingly and I can't wait to go out again.
Does your table mount to the eye bolts and rest on the fender?
misubisu
Another water tank idea . Only $179.00
That's use of the word 'only' I'm not familiar with Mike ;)
10 gallons it just under 38 litres.
40 litres of plastic water storage will cost around $40 and will be a fraction of the weight when empty.
I cannot think where you would mount this unit... other than in the place of the spare wheel or on the top of the trailer under the tent (which would be unsuitable).
I carry two plastic 20 litre water jerry cans, and for weekend trips I rarely use more than 25 to 30 litres. I'm researching an under tray solution to sit between the wheels underneath for when I do longer trips and need more water. There are lots of under trailer options, some even have stone guards. Ones that carry 80 to 100 litres are around AU$200 so would be around US$100 to US$150. Seems better solution that one of these steel or aluminium tanks.
mmrocek
Sorry, I do not have a good photo of it right now. Mine is resting on the eye bolts (dremeled the board down a bit there to be flush) and on the fender. I did drill a hole in the fender and the board is had tight bolted to it with a round head bolt and a wing nut on the bottom.
mep1811
Finished making the slider rack today. It's much easier to load up the slider, plus it utilises more of the centre space:
View attachment 521056View attachment 521057View attachment 521058View attachment 521059View attachment 521060View attachment 521061
What kind of mud flaps did you use?
Road trip. Visiting daughter in Twin Falls before heading to Colorado.View attachment 521807View attachment 521807View attachment 521808View attachment 521809View attachment 521810View attachment 521811View attachment 521812And some modes done. Moved the tongue box back after relocating the spare tire to the rear. Bought a smittybilt bumper and tire carrier. Had a bracket welded to use the trailers trailer hitch and the two recovery points. Also modified the jack brackets to work with the bumper. Propane tank mounted on a power tank bracket. Also Friday missed up most of the electrical. The ac charger for the lithium ion battery works great. Still need to work out n the solar panel when I get home.
Do you mind sharing what part number bumper and tire carrier you used? Looks factory.
misubisu
Most in the US don't appear to use mud flaps...
Mud flaps are a legal requirement in Australia, and I had to fit them to get the trailer registered.
I made the mud flaps myself, wasn't hard or costly. They come out so that you can use the jacks if required:
523713
I also had to extend the wheel covers to completely cover the wheel, as this would have also failed during the rego check:
523714
oskarf150
