UJOR Build Thread
patoz
Same here, but is it Blue or black? If I had a van, that is the front end I would want on it. I like it so much, I would put the same F series version on my F250 if I could find one in chrome. Does anybody know if they even come in chrome?
ujoint
Supporting Sponsor
It's blue. What would you want in chrome?
patoz
Chris,
I was asking if that style of front grill with the sealed beam headlights for the 2004 F250 PU Truck came in chrome. The only time I have seen that style of grill is on work trucks, and they were all black. Everything else is chrome on the front of my truck, and I'm about to install a Warn polished stainless Transformer Brush Guard and Winch Mount with a ZEON 12-S Platinum Winch, so the grill needs to be chrome also.
ujoint
Supporting Sponsor
Chris,
View attachment 536542 View attachment 536543
Gotcha. The grille on that van is a standard E series, headlights are from Rigid and we smoked the big amber turn signals.
blakeape
Hey Chris, can’t wait to unjoint my 1998 7.3 E350. I’ve got the 60 and Sterling. Which 271 t cases work on which engines? Will one from a 5.4 bolt to a 7.3, V10 or are they specific to each engine? Thanks
Jake
ujoint
Supporting Sponsor
Jake
Sounds good! You'll need a 31 spline input NV271. They were in the 99-02 F series with auto transmission.
ujoint
Supporting Sponsor
E450 Jayco is mobilized! Such a killer rig. More pics & video next week.
One gets done another gets torn down! This CA based little guy is going to be saweeeet.
stevelx450
Hi Chris, i couldn’t find the blue van above on your web site, do you know how much lift and what size tires it’s running ? I assume it’s your kit.
I will be installing your 6” kit on a 94 with sliding side door, i know about the MG hinge mod (probably doing that so i can use the standard width bushwacker flares) and how smb has wedged the lower part of the inside slider door, ( dont care for that idea ) do you have any other options to get the door to clear the standard bushwacker flares and what is the largest size tire i can run with a MG hinge mod?
I know i need to change the rear bolt pattern to metric to match the front , what year trucks might have the narrowest width metric rear axle so i can get the biggest tire inside the flare ? My goal would be a 35x12.50 tire.
I know it sounds strange to not match the front width but the slider dictates a narrow rear end .
Thanks for your time , have a great weekend !
Steve
ujoint
Supporting Sponsor
Steve
It's a 6" on 35s leaf swap. Sliding door clearance can be tough, even with the hinge mod and the narrower flares from B/W the door can hit the tire if the van has spacers and a 35" tire.
I would recommend to do a front hub conversion and keep the van 8 on 6.5 with no rear spacers. Modify the hinge, run the narrow flares (BW 22006-11) and you should have full clearance to the door.
ujoint
Supporting Sponsor
E450 jayco is mobile, ready for road miles and a few final touches.
New Fairleads! Will be available clear coated like this and in black.
ujoint
Supporting Sponsor
Day 2 for the CA Born Free rig, got a lot done! Ready for exhaust, rear gears, airbags, shifter, F bumper, wheels/tires.
ujoint
Supporting Sponsor
The 5th annual Asheville Van Life Rally will be next weekend here in Fletcher NC so if you don't have plans get your tickets now! Over 400 rigs are expected, we'll have a nice variety of our creations on display with the whole UJ crew. Come have a beer.
