Sprinter 4WD Conversion Idea, GMT-800 IFS.
Buddha.
Finally in expo white.
I was putting all the spare trans parts together to reduce the storage space. I discovered I have one extra clutch stack... ?
Not sure how it happened, but There are no B3 discs in the trans. So it has to come back down, and apart. Really pissed for not noticing. Honestly I don't know when I will have the motivation to do all that over
Those little mistakes suck.
I once rebuilt a 700r4 transmission for a friend. We got it back in the truck and forgot to set that pesky TV cable. The trans burnt itself up in a week. I didn't like rebuilding the trans a second time but I was starting to get pretty good at it by that point.
Stevemo
It's always better to know. I told my boss I had lost a bolt on an engine with a blower and we searched for quite a while until it turned up. He wasn't going to start the engine until the bolt was located. :D
shade
Lucky find. You're starting with clean, fresh parts, and you were just in there. It won't be nearly as bad as it could've been.
luthj
Engineer In Residence
Yeah, I am getting pretty good at tearing these things down now. The annoying bit is the b3 is on the output shaft, so I have to remove the tcase, and the peened nut. I figure I can have the trans down in about 2 hours, and the clutch pack installed in another 2. Assuming nothing is stuck... I used loctite on some of the tcase fasteners, so I need to dig out my torch... So many bolts that need a torque wrench!
According to the service manual, the B3 clutch is only used in reverse! If I had parked the other way, I may not have noticed for some time....
If the weather is good I am going junkyard hopping tomorrow for a driveshaft. Depending on my level of trans rage, I may opt to fab the trans mount and dipstick before I remove the trans. That will give me some time to paint and weld them while the trans is out.
I hope to have the final choices on the subframe made this week. And I can send for a few laser quotes before the end of the month.
Len.Barron
a few versions of silverados have 70-80" long aluminum driveshafts, they might be good donors for you
luthj
Wandered around the yard for an hour. As expected the gorillas with forklifts have bent 99% of the longer shafts. I found a handful over 75" (too long) and just one that was roughly the right length. It was a 97 F250 2wd 139" WB. Nothing nearby, so the search continues... I need about 74.25" center-center length. A bit shorter is okay, and maybe 74.5" would work. I sent a couple quotes to places within an hours drive, I will see what comes back.
Mwilliamshs
Driveshafts under rigs with IRS usually survive the forklift. Think the aluminum one under my half ton dodge was from a v8 ford explorer. 2004ish i think
luthj
I looked at a few explorers with the IRS. The ones on the lot were too short. I will do a google to see what shakes out.
Trans support is coming together. I wont post a photo of the welds, too embarrassing. I really need to get a new welder, I think the feed motor is starting to glitch a bit on my ultra-cheap refurb unit.
luthj
Got it bolted up. Still need to drill clearance holes for tightening the nuts. I had to slot the outer holes a bit, not too bad for hand drill on a bench I guess. The trans/engine final position is about 1-1.5 degrees lower than stock. Its possible I won't need to shim the rear axle, but I will wait for the first test drive to tell.
Do you have an auto dimming adjustable helmet? I found my welds improved markedly when I switched to one. Apparently being able to see is a big deal!
Yes I do, but my old eyes don't adjust well to the immediate change when the arc strikes. Especially can't see well when doing inside corners.
shade
? - Any neighbors shooting you the evil eye yet?
You'll have to keep an eye out for someone trying to use that as a jack point for the whole van. I know you're usually going to be the one doing any work on it, but I can see someone at a tire shop deciding to save some time lifting from that crossmember.
I recently tried Corroseal latex rust converter & primer on some scabby bed bars I sold with my RTT. That stuff works great, and is very easy to apply with a foam applicator.
luthj
Yeah, my old trans support was already bent from a previous encounter with dumb person. With some reinforcement the new one might handle 4,000lbs, but I don't trust the vans structure it attaches too... I have been meaning to paint the jack points bright red or yellow for years now, not sure it would help, but can't hurt.
I may put some of that rust converter in the cart. The mill scale has historically caused issues with those products in my experience. I picked up a gallon of "Chassis Saver" coating, which is a urethane based raw metal primer/topcoat. Hopefully it does a good job.
iStan814
