Ski Bum Truck V2.0, F450 Rough Road RV
Alloy
Warranty Terms & Conditions:
For full Terms & Conditions of Sale including Warranty & Returns policy see Terms.
Additional Conditions For Sherpa 4x4 Winches:
  • Your Sherpa 4x4 Winch must be serviced every 12 Months by a suitably qualified professional.
  • A copy of service receipts must be presented for a warranty claim.
  • The winch should be used with a minimum 650 Cold Cranking Amps battery
  • The winch MUST have at least 1 complete layer of cable/rope on the drum at all times, the cable has a red mark which identifies the minimum that must remain on the drum.
  • The winch MUST be mounted to a suitable winch compatible bull bar or winch cradle only.
  • The winch MUST be used as per the instruction manual.
  • Do Not use the winch for industrial or commercial applications
  • Do Not hook the winch cable / rope onto itself
  • Do Not exceed the pulling limits of the winch
  • Do Not shock load the winch
  • Do Not overwork the winch. The drives, like on all winches, have a duty cycl
java
Interesting..... Sounds like an easy out.... Too bad, as I am interested in one, but certainly not going to pull it out of the bumper and have it serviced yearly.
motorman
i read someplace where you were considering a radiant floor loop of hot water
what was the reason you declined this path?
im considering elgena system that total composites packages.
java
I had not really considered it, but doing it again I certainly would! Warm floors would be so nice in the winter.
It seemed like a more complicated system when I was designing things, and I just kind of put it away. A shared heat loop with the engine, to use for heat while driving, and engine pre heating would be a nice benefit also, but does add a bit more complexity.
I was not familiar with the Elgena system, I am not sure a 12v on demand type heater would do it. I would look into the webasto/espar type water heaters if it were me.
java
Well I have been noodling all week, I am leaning towards no winch in the front. I think if I need one, its going to be needed going backwards. Last chance for votes :D
Pacific Northwest yetti
Expedition Medic
fair enough, it would have to be well built as far as the carrier and receiver mounts. Probably a better idea to go fixed.
we have had some class IV, V stingers used to haul some pretty heavy critters and equipment. But even at that its something like 15k, rated which would be close to 1/2 or so of breaking strength- 25-30k.
and the Pintle hitches used by our big rigs, but those are direct to the frame.
luthj
Engineer In Residence
It wouldn't be too hard to fab up a bolt/weld on pin type receiver mount for a 16klb winch. Alternatively you could rig a cradle that will accept two short lines to your frame rail recovery points. With a short jumper for electric power, you could attach the winch front/rear, or even on one side.
java
Yes If I was to do a hitch style I would do a double receiver.
Could do a cradle, but that seems like a lot of additional rigging/failure points....
patoz
I have a portable Warn 9,000 lb. winch that is setup for the front right now, but it will be replaced with a new Warn 12,000 lb. ZEON Platinum 12-Sw /wireless controller, and will be mounted in the Warn stainless steel transformer bumper mount. One that is done, the portable will be designated for the rear bumper.
Alloy
Few years ago I fabbed a mount for a 20K winch. I copied the bolting sytem/locations used for a quick disconnect snow plow.
java
Very interesting idea! But I have a bumper getting bolted to the frame horns.
Sent from my SM-G973U using Tapatalk
xander69
