M100 aftermarket axle for Toyota bolt pattern
old_CWO
I think the Toyota style lug with captive washer will not concenticly affix the toyota alloy wheels without a hub ring
Aren't they functionally the same thing as regular mag wheel lug nuts, just metric? I would think it's no different than old school lug centric mag wheels on muscle cars. Those are centered on the studs via shank lug nuts that are precise in the wheel holes and just the right length to tighten without bottoming out. Why won't the stock Taco nuts and wheels do the same thing on a trailer hub with metric studs?
jwiereng
The ones I have are not a precise fit between to mag lug shank and wheel holes.
old_CWO
Well, if that's the case then it obviously wouldn't work. Interesting. I would swear that wasn't the case last time I messed with the Toyota OEM stuff. I think I have a 2nd Gen Tacoma TRD alloy wheel and factory lug nuts laying around. I will measure this weekend and report back. I assume the 4R setup is similar enough to the truck as to be a good comparison.
old_CWO
As promised: the holes in the Tacoma alloy wheels measure .745, the stock lug nuts are .725. I think the fit tolerance should be .001 to .0015 for lug centric wheels. You are absolutely correct - this combo will not work.
So the hub centric spacers seem to be the path of least resistance for running Toyota alloys on the trailer. I doubt there is a mag wheel lug nut in either thread pitch (trailer 1/2-20 or Toyota 12-1.5) with the correct diameter shank.
Bummer. It would be nice to not have that extra piece in there.
jwiereng
Thank you for the measurements. Seems like even if a metric stud was found, and pressed in the Toyota OEM style nuts would not center the wheel.
I also want to avoid hubcentric spacer, maybe there is a hubcentric ring that would work.
E trailer says dexter 3500 6 on 5.5 hub has a center diameter of 3.09 inch (78.486mm) Diameter of Outside Center Hub Bore for Dexter 3,500 lb Idler Hub
Toyota 4Runner/Tacoma/ FJ wheels are 106mm
seem like we need a 106mm OD x 78.486 mm ID hub ring.
jwiereng
Also found this one Very close to the correct size from motorsport-tech. Same operation that make BORA spacers
106mm x 78.1mm $25 each Alu
I wonder how close tolerance is necessary. Do you think 78.1 mm will be too tight on 78.486 mm ?
old_CWO
I would think no more than 1-2 thousands (.025mm - .05mm) larger than the hub would be about right. That's sort of typical shaft to bearing clearance for machinery. The spacers you found are about .015 undersized to the hub, I don't think those will fit for you.
Couple of options; call Motorsports tech and see if they can custom make something. I know they do a lot of custom stuff at their facility.
Or, buy the ones you found, take them and your hubs to a local machine shop and have them open up the bore on the aluminum hub rings. If it were me, I would have the machine shop make them with an interference fit and press them on. That way when you remove the wheels for any reason the hub spacers stay in place.
Heck, the machine shop can probably make what you want from scratch just as easy and skip the extra step. Give them the trailer hubs and a wheel then let them go to town. This would guarantee everything fits up as planned and you could have them done in steel instead of aluminum.
I would definitely want everything in hand to verify measurements before proceeding. Not sure I trust the precision of the trailer hubs...
This of course assumes that you are still going to use the Currie metric studs and Toyota OEM lug nuts.
Kymudder
Is this the 1/4ton military jeep trailer? I’ve been somewhat looking for one with no luck around western ky, only found the bigger ones for deuce.5s
jwiereng
Not easy to get a machine shop in my area to take this on. Most have enough good paying jobs that are not thrilled about jobs with ones or twos.
Maybe I can get some time on a lathe myself. I don’t have one. I do have a mill and rotary table.
Any machinists on the forum that could give some tips on how I could make using rotary table?
PSea
looked high and low for a solution to this problem. spoke to many wheel experts about it. a pair of rough country spacers did the trick. cost less than $70 total. done!
Carb850
So to get a new Dexter Axle I pretty much need to get wheel spacers, correct?
Any reason not to get a new axle outside of keeping it original? I'm modifying this to fit my needs so originality is not a concern of mine.
old_CWO
It seems that using hub centric wheel spacers is the easiest way to run factory Toyota alloy wheels, yes.
There is no compelling reason I can think of not to use a new axle except perhaps losing the factory parking brake feature. Modern electric trailer brakes are available with park brake option if necessary. I'm a wheel chock guy but the park brake is sort of nice.
micoinde
As with the OP, I want the same wheels for both my Tundra and trailer.
Do they make a 5 x 4.5 inch bolt pattern to 5 x 150mm Toyota Hub Centric wheel adapter?
There seem to be many options for putting after market wheels on Toyota hubs but I can't seem to locate an adapter to put Toyota Tundra TRD wheels on my trailer.
Mischief
I measured the backspace of the wheels/tires and ordered axles by length to make sure I had clearance without spacers. Dorman makes metric studs to use with the toyota lugnuts, I don't remember the #. I think tacoma rims (at least the 1st gen) are both or either hub or lug centric, I've read both. In any case on my trailer they are lug centric and I've had no issues.
