Toasty
Weighed the truck at all 4 corners; front left was 1300lbs and the rest were 1200lbs. Ordered a pair of Kings from Accutune, the first set got straight fittings and i ordered the second with 90's. I'll get 90's for this set later. Painted all the bare steel and installed the shocks to finally sit the truck down on its own weight after four months.
Wrapped mine up with some new double cardan driveshafts, interesting thing was that the Montero 9.5" rear diff pinion flange had the same pattern as the Ford F-250 but metric and female. Tom Woods was able to machine a pilot to fit the Montero pinion flange and Ford 1350 companion flange so all i had to do was use SAE bolts. Made some good progress on PA_JERO's SAS as well by this point, every time i made a part for my truck i also made his parts. I started mine 2 months before i started his and finished them both weeks apart.
