2016 Chevy Silverado LTZ Z71
buellconvert
The Zone kit definitely send like a well built and complete kit, even has bumper brackets to return everything to stock appearance...it's definitely a very involved process.
Sent from my moto e6 using Tapatalk
D45
I wonder in theory how long if would really take for the Zone lift to install
Install sheet says 8 hours......seems very excessive
It take around 3 hours for the 2.5" suspension kit
buellconvert
I did a very similar body lift years ago, in my garage with normal hand tools, by my self and I did it after work one evening, I agree on the 8 hrs sounding a little excessive
D45
Thanks
I am certain I could get both the suspension lift and body lift installed in 8 hours
Just appealing for the price and the amount of lift.......all while maintaining good cv axle angles and ball joint angles
I won't have to mess with new upper control arms, drop diff spacers or notching the crossmember.
Save money for new rear shocks and tires this way
D45
Do you need the extra 1.5" to fit the tires you want to run?
Maybe yes.......a huge perk is running a small 2" front/3" rear kit with the 1.5" body lift
I want to keep good cv axle angles and ball joint angles
I won't have to mess with new upper control arms, drop diff spacers or notching the crossmember......something I'd have to do with a suspension kit over 3"
buellconvert
Once you start going that far with these trucks it's just opening up a can of worms and you're always chasing one thing after another...I completely agree with you on wanting to keep the suspension at 2"-2.5" max, same thing I've done with mine.
D45
What tire size are you running ?
D45
Cap is on and looks good. The taller bulkhead gasket was too rigid and too tall. Left a decent gap. I removed it and will see how it does with just a single layer of flat gasket material
Definitely need more internal lighting
I added a stick on handle for the inside of the front sliding window
I will install the GM bed tie down hooks today
gp01
