rayra
Multiple sets per u-joint set?
Delcos were good enough, I ain't picky.
This morning it was reinstalling the front shaft and turning a test drive into a cheeseburger hunt at lunchtime. After I came back my magician's assistant was able to slowly inch the vehicle backward in the driveway while I lay under it seeking the perfect angle to access the grease fitting on the frontmost u-joint. No worries, I had a large rubber wheel chock between the front tire and my rib cage.
/there's a reason I don't have a large life insurance policy, I'm worth more alive than dead.
Then the afternoon I rigged the Suburban on the redneck hoist in preparation for the fuel pump replacement and kicked that off with the rear driveshaft removal and new u-joints in it.
That was going well enough, melted off 4 caps, got the rear end joint fitted, even got the grease fitting facing the right way, then I got the joint set in the front end of the shaft, with the other two bearing caps careful set to the side [in creative writing this is called foreshadowing], while I gloved up and got my hand in the hot yoke ears to push the new naked u-joint towards one side as I set that cap into place with taps from Mjolnir. Then I rolled the shaft over 180deg to position the other side and [here it comes] ... pushed the other two caps off the table on to the floor. Tiny little roller bearings everywhere. Mixed in with the torched trash. Much cussing ensued. Vanna and I got busy imitating a passel of kids after a pinata has been ruptured. For time's sake we just picked up every bearing we could find. Then I got back to setting the 2ns side cap while the yoke was still hot and expanded and it was easy to set the cap, using my barbarian methods.
Then I took all the pieces of Humpty Dumpty and his twin brother in the house to make good use of my circular fluorescent / magnifier swingarm lamp on my home office desk and got busy sorting and re-stuffing greased caps. The new bearings are smaller / slimmer than the old. Plus the old ones were covered in cooked grease, while the new had some blue goo. So I set about setting them all about and came up a couple short. Went back thru the gleaned pile and found them hiding out. ta-da, found them all.
I didn't really test the old u-joints before I took the fire wrench to them. At 146k mi it scarcely mattered, bound to be wear. But I did notice as I set the transmission yoke up for its sacrifice to Pele just how amazingly worn the U-joint shafts were in the needle bearing contact area (highlighted in red)
Then it was on with the show.
Rear drive shaft ready to re-install after the fuel pump is in.
Fuel tank removal probably commences tomorrow after morning classes. I've been scudding around the last couple trips with the 'Low Fuel' lamp lit. So the tank shouldn't have much spam innit. I could probably get away with just tipping the end of the tank down, but I want to finish the tank plate prototyping so will probably remove it entirely. Depends how much of a PITA the plumbing is.
