2016 Chevy Silverado LTZ Z71
D45
Both LED fixtures are in...…...going to get them mounted and wired up hopefully tomorrow
Still not sure which I will use
Snapchat-673551634.jpgSnapchat-696454717.jpgSnapchat-1160925010.jpgSnapchat-1292429427.jpgSnapchat-2129084709.jpgSnapchat-673551634.jpgSnapchat-696454717.jpgSnapchat-1160925010.jpgSnapchat-1292429427.jpgSnapchat-2129084709.jpg
D45
In the bed, on the passenger side (near the tailgate) I have a milk crate secured to a tie down.
Its packed and over flowing
I decided to spend $130 (used of course) and order a Swing Case tool box for the rear driver side of the bed
The added storage will be nice and having the ability to swing out the box towards the tailgate will be nice
SoTxAg06
Be careful not to overload them weight wise. Ran them for awhile on a tundra I had. They did ok keeping things dry. The brackets will bend if you put too much weight in them. You also run the risk of the plastic cracking.
D45
THANKS!
The heavy objects will remain in the milk crate
Just looking for storage for the ratchet straps, tie downs, tow ropes, gloves, etc
SoTxAg06
THANKS!
They will be good for that, especially under a camper shell. Mine were just in the bed without a cover. I thought about getting one for my current truck, but haven’t fully committed to it. If it do, it will be for holding a recovery strap, and a few items like that.
Mekcanix
Camper
I have been using a retro fitted swing out box for over a year now and I really like it.
I will check on the overloading it as I have a ton of crap in there including my 10 ton bottle jack.
mine was new in box but the guy got it for the wrong truck he had a Colorado and the box he ended up with was from a titan. I had to tweak it a bit but its in my sierra with no issues so far ?
D45
Well I ended up using all 4 of the small LED lights........quick install job in less than 2 hours
Much brighter......all mounted on the rear aluminum window channel
D45
The 3.5" Superlift lift kit arrived last night...……...I need to unpack everything and double check all the parts were included
Need to find some rear blocks...……...does anyone know if the factory 1-1/4" block is tapered?
SoTxAg06
Rear with 2.0” Blocks (Stacked on Stock Blocks):
Driver Rear: 39.875”…………………..1/8” taller than front
Passenger Rear: 39.125”……………..1/4” lower than front
Rear with 3.5” Blocks (Not Stacked – 2.25” rear lift):
Driver Rear: 40.125”…………………….3/8” taller than front
Passenger Rear: 40.375”………………..1” taller than front
Rear with 4” Block (Not Stack – 2-3/4” rear lift):
Driver Rear: 40.625”…………………….7/8” taller than front
Passenger Rear: 40.875”………………..1.5” taller than front
I am going to shop for some 3.5" tall blocks so I don't have to stack anything
Check out CST suspension. They have fabricated blocks for Chevrolet 1500s in various sizes.
D45
They only sell blocks in 1" increments
Superlift's block is 2" tall and the factory block is 1-1/4" tall
I need a block that is 3.5" tall
D45
The factory headlights and fog lights are decent on this truck, however there's always room for improvement
I am planning on a front LED light bar, to hide behind the grill area
I have the old bar off my F150 that I will attempt to use
D45
This truck is a 2018 Silverado Z71, running factory 18" wheels with a 2.5" front / 2" rear lift block with 295/70R18 tires
295/70R18; 34.3 " x 11.60"
I am really wondering about this setup...………..looks like factory 18s
Wish I knew who the owner was to see if much (if any) he had to trim
D45
Looks like some behind the grill LED bars interfer with grille shutters
Now, how do I know if my truck have these grille shutters?
Based on what I see, this feature started in 2017?
gp01
