Jeep XJ Pop Top Camper Build
CraftsmanCollaborative
Homebrewed "Lizard Skin" Rubber layer for the inner door/body skins and wheel wells.
Laid down real thick with a hopper gun. This is an imitation of the sound control coating that goes on first.
Second Lizard Skin imitation layer. "Heat control"
Ceramic Microspheres from the glass supply mixed around 1:1 and spattered with a 3mil gun.
Thick spatter on door/body skins and exhaust side floor pan. Full coat to follow.
Bed Liner time. The cab is all enclosed and the rig is being built to handle full-time living.
The Duplicolor worked well:
Waterbased-Polyurethane. Voc content is ~130g/l IIRC, hardly reeks opening up the can.
Thin, watery, and clumpy even mixed. I wouldn't bother rolling this type.
But it sprayed great.
I managed to cover the whole lower of the rig with 2 quarts.
Used up the first quart from the seat mounts forward. Used the hopper gun to get that thicker traditional coating.
This is the only area that will see foot traffic/wear.
Poured the second quart into the 3mil gun. Far better coverage with this texture.
The bed system will sit over all of this with storage inside, so it doesn't need quite the thickness of an actual truck.
