Iain_U1250
Looks very flash Simon, all things take time when you are doing that amount of custom work.   You still have a few years yet before you are beating my record
			That looks amazing. Are you going to bring the lift eye higher up. It seems that with the weight of the tires you would be below the center of gravity. How does it work when you are of balance with one tire shredded?
Love the panel recesses in the tire carrier .. another starwars flashback
One of the things to try is can she get a completely flat/shredded tyre back on the carrier. When I made my wheel tie down we tested all sorts of scenarios, we had to make sure we could tie down a flat wheel on the roof, meant I needed a bracket that could hold a deflated wheel which was 100mm thinner and an inflated wheel and tyre.
Starwars flashback... We recently added a pneumatic door strut to our entry door. Every time we open it, it reminds me of the original Star Trek TV show when doors opened. Now if only this truck had warp speedThat looks amazing. Are you going to bring the lift eye higher up. It seems that with the weight of the tires you would be below the center of gravity. How does it work when you are of balance with one tire shredded?
Nice work Simon. My truck would do a wheely with that tank ?And now every time I look at the back of the truck, I too see Star Wars!! Thanks!!!Anyway, back to it. I have one space left under the rear of my 'Imperial Fighter' Overlander. I have had Chris at Abber Tanks in Queensland make a tank to my dimensions. Here it is.
Here's the carrier I have made for it which has two roles. The first is to carry the tank, and the second is to give additional support to the two underslung lockers.
Here's the tank mounted in situ. There will be two drain points. Both with a tap located just behind the rear mudflaps, so they're protected and it gives us the option of which side we drain the tank too. This will only be used when we are in a mainstream camp ground.
 Oh the frustraition of having to go backwards to go forwards ?
