djschlo
TBD
Body mounts: With the new hardlines and fuel harness installed, I replaced the body mounts and put the body back on the frame! Energy suspension’s kit (from Marlin Crawler) recommended using original manufacturers torque values. I couldn’t find the torque specifications in my factory manual or online. I went with 25 ftf lb. as that seems to be the point the washers that sandwich the bushings make contact with the bolt sleeve that is inside the bushings.
Hood: With a 5VZ swap, you can either run a body lift or cut the hood and add a hood scoop. I am not a fan of body lifts, so cutting the hood it is. I ordered a hood scoop from toyotafiberglass.com. It’s nice, but pricey for something that didn’t come with instructions or a template given that’s its designed for this vehicle. Not sure where the hood will need to be cut for the 5VZ so I looked at swaps online and made educated guesses by generously marking the hood with sharpies for both a supercharger and naturally aspirated 5VZ. Haven’t cut the hood yet, but I mounted the scoop using the 4 studs and nuts it came with. I’d like to make a grill for the scoop to help keep debris out of the engine bay. I’ll fiberglass the scoop onto the hood permanently once I make a grill and cut the hood for the engine.
Next: I scored another gear driven (R1FA) transfer case! I guess I am doing dual transfer cases now.
I am nearly done installing the “new” front clip. I will wrap that up and start fitting the new fiberglass fenders tomorrow. Paint will follow but I still need to pick a color and more importantly learn how to paint a vehicle. Woohoo!
