Your rigs weight distribution is likely different than mine. In mine, I’d be most concerned about rear traction. It’s got 6000 lbs over the rear axle. Experience has shown that both rear wheels will stay on the ground and front wheels will be airborne quickly. Thus making open diffs and LSD less useful. I’d not want a locker that I can’t control there because I find open diffs steer better in the snow & ice.
I’ve had an Fj40 for 29 years now. In ‘92 I rebuilt the rear tub with 1/8” steel steel. The relevance being, it now weighs 2000lbs in the front and 2500 lbs rear. It’ll go almost anywhere with both diffs open. Most places it’ll pass other 4x4s in 2wd. On snow and ice it steers well (at reasonable speeds) so long as I’m delicate on the throttle. Once both front wheels are spinning, turning steering is less productive. With an open front diff, one wheel isn’t spinning, it’s the wheel with the best grip and thereby I’ve got something to steer with.
My first choice would be LSD in the rear, and open in the front, If you’ll be doing more serious wheeling, locker in the rear and selectable in the front,
that said, I’ve not got your rig, nor do I know where you plan to drive. So do what makes sense for your situation.
