Land Rover ideas for Jeeps
jscherb
The ladder is always on a firm level surface.
That makes sense and I think that would work well on the flat metal bumpers of a Land Rover or a TJ.
Also makes the ladder shorter, I've had instances where the ground on the ladder side of the Jeep was lower so the ladder wouldn't reach the ground properly. I've got a ladder extension for mine so it works out ok but it would be nice to never need the extension.
It wouldn't work on a newer Jeep like a JK - the plastic shell of the bumper isn't in contact with the metal bumper underneath so the ladder would likely crack the plastic shell - some sort of ladder mount would need to be fabricated to go over the bumper.
jscherb
That old CJ-6 is right up my alley. Even has a "barn door".
It also wouldn't be a very difficult hardtop to build in either metal or fiberglass - all flat surfaces, the mating points on the tub are all straight lines; no compound curves anywhere and a flat barn door.
jscherb
I wish someone would make a stretch kit ("TJ-6") for the TJ that would let you use an LJ top.
There's a group on Facebook devoted to lengthening YJ's that way: https://www.facebook.com/groups/YJUnlimitedbuilds. It's a private group but if you ask to join you might find a lot of good ideas there; lengthening a TJ wouldn't be much different than lengthening a YJ (and BTW if there were such as kit as you wish, the one kit could be made to work with both YJ's and TJ's).
Jurfie
I've installed my RTT to open off the back and off the side, but never this way:
I'm trying to come up with reasons to install it to open over the front like that and haven't come up with any other than it reduces the overall footprint of the vehicle + RTT when set up. Anyone have a reason this would be a better setup than off the side or the back?
Maybe for tall gorillas like you and I? Install a batwing/270d awning a little higher up to have more headroom?
Jurfie
Back in November I posted about the Ineos Grenadier, a 4x4 from a new company that picks up where the Defender left off (https://expeditionportal.com/forum/threads/land-rover-ideas-for-jeeps.218029/page-25#post-2854710).
4WD Magazine (from Canada) recently posted this video about it:
Not really a Land Rover Idea for Jeeps, this is more like a Land Rover Idea not for Land Rover :).
I'm looking forward to these being released; I can only imagine that the price will be such that it is high enough to pay for all that R&D (and hopefully survive), but also high enough that I can't afford one. :cautious:
jscherb
If you've ever been to Italy maybe you've seen Defenders belonging to the Carabinieri - a police unit of the Italian army:
This small item appeared on the last page of the January issue of Land Rover Owner:
The item didn't say specifically which Jeeps would soon be part of the Carabinieri, but I'm guessing it'll be the AADS Utility:
Jeep F.T.W.
jscherb
A few weeks ago there was some discussion in this thread about using the space under the Jeep for storage or something. This is from an article in the January issue of Land Rover Owner:
I direct your attention to the second callout in the photo above:
GO WITH THE FLOW: the 70-litre fresh water tank is fitted internally, so there's no risk of freezing in harsh winters. There's an external locking filler in the rear quarter panel.
The water tank is fitted in the spare compartment under the floor (notice the spare now on the roof rack), so it's not truly under the vehicle, but it's an interesting implementation nonetheless.
The article says:
There's hot and cold running water. A heat exchanger in the engine bay feeds hot water to the tapon the rear door, while a connector on the front bumper receives a shower connector. Temperature is controlled via the Disco's heater controls while the engine is running, meaning Katrina can enjoy a hot shower any time, and literally anywhere.
Unfortunately there's no further information in the article about the water system, nor are there any further photos than the ones above.
What about something like this for the Wrangler? There isn't a compartment like that in the Wrangler, but there is some space underneath the Jeep. For those interested in mounting a water tank under a JKU, Dan Grec's excellent article is required reading: http://theroadchoseme.com/diy-4x4-water-tank-pump-filtration-and-treatment. Everything you'll need to know about is in that article. Dan's Jeep is a 3.8L JKU and he says the dimensions under a 3.8L JKU should be checked because they may be different than his. I checked, and find these dimensions, the length available under a 3.6 model is less than Dan had under his 3.8 model:
The tank could possibly be taller than 6", but I'd recommend a skid plate under it if you have a taller tank. The fuel tank, which is on the other side of the driveshaft, has a skid plate with a height that might allow a 7" tall tank but you'd have to check.
There are a number of RV water tank suppliers and I did a quick search to see if there are stock tanks that might fit in the space under a 3.6 JKU. Here's one that should fit, although at 18.5" long it would leave almost 6" of length space unused. Perhaps with more searching a longer version of something like this could be found: https://www.ntotank.com/5gallon-ronco-rv-water-tank-x4711116. It's only 5 gallons, if a 24" long version of this could be found it would be about 6 gallons, which is probably about all you could fit in the space under a 3.6 JKU.
Zeep
Doesn't someone already make one, that fits into the rear floorboard area?
Either one would be good for low CG.
Clymber
I had one of the frontrunner water tanks in my tacoma and had a 12v push button faucet hooked up. It holds 11 gallons which was great. sad to say with the 60% delete I have on the jeep this will never be an option for me
jscherb
Here's an idea... if you've done a 60% delete and have a compartment on the floor like mine:
You could probably fit one of these 10 gallon bladders in the compartment:
There might not be enough space to allow the bladder to be filled to maximum capacity, but being flexible it should form to the space available.
If that doesn't fit there are 20 liter bladders that will: https://www.amazon.com/Sturm-Military-Surplus-Swiss-Liter/dp/B003P43Q5Y
jscherb
As long as we're on the subject of running water, here's how I do it in my Jeeps...
I use 2-gallon Rotopax water containers for my water supply. The "active" one mounts either on the side of the Trail Kitchen housing:
Or, if I've got the kitchen drawer unit installed, on the front of the drawer unit, just behind the back seat:
The pump is mounted on the front of the Trail Kitchen:
In cases when I want a water supply/pump but don't need the full Trail Kitchen installed, the pump mounts under the kitchen battery; it's behind the aluminum plate on the Molle panel.
I actually have several pumps left over from when I was designing the Trail Kitchen sink option so the one behind the Molle panel can stay there all the time.
The pump is a demand pump, which means that it has a pressure switch that turns on the pump when low pressure is detected (when the faucet is opened) and turns off the pump when pressure builds up (when the faucet is closed).
The output of the pump is routed to the sink:
The pump plugs into the Trail Kitchen power panel; when the pump won't be in use I pull the plug.
When I don't have the Trail Kitchen installed, I've got a separate power panel that hangs on the battery cover that the pump can plug into.
A two-gallon Rotopax is a good amount of water but for a longer trip more is needed. There are lots of places to carry Rotopax.
The MORryde Overhead/Swing Down Molle Panel can hold two 2-gallon Rotopax or one 4-gallon (only one 2-gallon is installed in this photo):
There are lots of other places to carry Rotopax on a Jeep - on the tailgate hinges, on the spare tire, on the door hinges, on the MORryde JK side mount, on a roof rack... point being, you can carry plenty of water in 2-gallon Rotopax containers because there are so many places to carry them. Also, an empty Rotopax makes a good "gray water" container if the drain water can't be drained onto the ground off to the side of the campsite. As a Rotopax gets emptied, it becomes the next gray water container.
When you consider that a 6-gallon water tank is about the largest that will fit under a later model JKU, carrying 3 (or more) 2-gallon Rotopax doesn't sound like a bad idea.
One other thing about portable containers like Rotopax is that you can carry them to the water source rather than driving the Jeep to the water source.
I don't mean to sound like I'm against on-board water tanks, but portable containers seem to work pretty well for me.
4xCoffee
