UJOR Build Thread
ujoint
Supporting Sponsor
Oh duh. D70 is the rear. It stuck in my head after your video the other day.
Ok, revised question. Could the coilover setup be done on a D60 front with less welding and custom work?
Not like this, we needed that extra width to make it all work.
ujoint
Supporting Sponsor
Another NY RV under the knife!
ujoint
Supporting Sponsor
so what is the main deciding factor between the 2 steering setups you mentioned? Tire/wheel combo?
One is our standard crossover steering, the other is our RSC upgraded axle. We often upgrade non RSC vans to the RSC axle for the bigger brakes and serviceable wheel bearings but it doesn't add the electronics of the RSC system. Obviously all RSC vans get the RSC upgrade, everything else can get either steering setup depending on how the van will be used.
BroncoHauler
Do you know if that TX big boy is painted Arizona Beige? That's been a favorite color of mine since I had an '02 F250 7.3L that color.
Herb
