ARB fridge stopped working off battery???
TexasTJ
Climbing Nerd
Ultimately fuses or other OCPDs are to protect conductors.
20A will be fine for protecting your 8AWG wire. Further, it will protect the appliance cord if it sustains a short circut.
Thank you for all the help I’ll grab a 20 amp and go!
TexasTJ
Climbing Nerd
Cool so what do you think was the problem ??
And How is the Voltage Now, ?
Voltage is constant at 12.7. As to the source ?‍♂️ Maybe the harness was just old. I’m also ordering if my solar panel might be masking a bad battery.
67cj5
Man On a Mission
Cool so just from changing the wiring the voltage has gone up from 12.3v to 12.7, Going to the bigger wire size would of boosted the voltage higher, Thats going to preserve the fridges electrics for sure. Well Done Sir. (y)
67cj5
Man On a Mission
When the Fridge was pugged in the voltage was dipping as low as 2.3
Mine using cheap wire will drop around 0.23v with proper wiring it drops very little, I haven't checked it with good wiring but I will test it out some time,
Ancientsojourners
