2016 F550 Custom Overlander - San Jose, CA - PRICE REDUCED $215,000
oliklink
This overland was built to keep you out there “indefinitely” with luxury. Top end material and equipment, regularly serviced, and optioned out.
Price: $238,000
Mileage: 45,000 miles
Registered in California (clean pink slip)
**** Ready for your next adventure: Oil & filter changed, new tires, engine maintenance done, clean pink slip (register in California) ... just need to top off the tanks! *****
2016 Ford F550, Crew Cab (XLT package), 6.8L V10 gasoline engine 4x4.
Goodyears g275 MSA 41” tires with spare (custom made front fender flares, full bead lock super single 20x11 wheels).
Custom designed suspensions (custom set of Deaver rear leaf springs, rear firestone airbags, Carli front coil springs, custom valved and tuned (by King) 3” rear remote reservoir shocks, 2.5” front remote reservoir shocks, PMF fab steering stabilizer).
Full custom composite construction seamed and molded (Line-x Ultra paint).
Custom subframe (extensive storage in locker assembly, Full Line-x paint).
Self-sufficient design (72 gallons gasoline tanks, 90 gallons fresh water, 40 gallons grey, 3 stage water filtration, 1,300 Watt solar panels, 11,000 Watt/hour batteries (4x Victron Lithium Ion), 3000 Watt inverter, Duo band WIFI Internet router, 7 in 1 mobile antenna).
Amenity riched (Indoor/Outdoor kitchen (4x induction cooktops, electric BBQ, microwave), 3x showers, 2x sinks, 2x fridge/freezer, Nature Head compost toilet, Espar D5 hydronic heater with Sure Marine Real air handler).
Luxury design (180 degrees front view, sunroof, European foam mattress, European double pane windows, multipurpose seating area).
Check the full description with additional images and VIDEOS at ***** https://www.oliverklinkphotography.com/OffGridLuxuryCamper/ *****
Recent Maintenance/Improvement:
- The unit was fully revamped (serviced & new addition) between December 2020 – March 2021
- New tow hitch
- New hoist for spare tire & equipment lift
- New truck battery (December 2020)
- New 2nd alternator and trickle charge electronics
- New WIFI router (PepLink Transit Duo) and Antenna (MobileMark 7-in-1)
- Serviced Victron equipment (Factory service & firmware upgrade)
- New ladder handrail and connectors
- New custom blinds & mosquito nets
- New pop-up lifters & rails
- New Nature head compost toilet liquid redirection
- New multi-use table (Dining, pull out monitor (27inch BenQ post processing monitor)
- New lights & plugs (reading, garage, outdoor)
- New storage pockets (cabin, camper)
- New iPhone, iPad, GPS holders (truck cabin)
- New light bar (Rigid Industry)
- New tires GoodYear G275 MSA (335/80R20) 41” (5x) – 15,000 miles on the tires (March 2022)
- Upgraded all equipment firmware. Remote monitoring and control
- Upgraded weather stripping and insulation
- New operation manual (parts’ list, schematic, description, instruction)
- New recovery gear (48,000 lbs recovery kinetic rope, serviced military jacks)
- Engine maintenance (brake, transmission, coolant, all belts inspected, no engine leak) (April 2022)
- Selling as I am again traveling internationally extensively
Weight & Dimension
• 17,340 lbs (fully loaded – 90 gallons water, 72 gallons gas) - Front axel: 5,760 lbs - Rear axel: 11,580 lbs
• Length: 24 feet (with bike platform: 25.6 feet)
• Width: 7.95 feet (with mirrors out: 8.6 feet)
• Height: 9.7 feet/12.7 feet (Camper Up)
• Wheel base: 14.75 feet (between axles)
Suspension
• Custom set of Deaver rear leaf springs
• Rear firestone airbags
• Carli front coil springs
• Hydraulic bump stops on front suspension
• PMF fab steering stabilizer
• Custom valved and tuned (by King) 3” rear remote reservoir shocks, 2.5” front remote reservoir shocks
• Custom made front fender flares & Front bumper (Buckstop, Boss model)
• Full bead lock super single 20x11 wheels
• GoodYear G275 MSA (335/80R20) - 41" tires with spare
Camper Body & Sub Frame
• Full custom composite construction. All molded, seamless
• Lifting roof design with 4 corner electronic linear actuators from Linak with IC parallel control system
• Double pane European Windows throughout (Outbound). Custom roll up blinds, mosquito net
• Double pane European sunroof (Outbound), blind
• Front middle wall assembly operates independently via linear actuator and a cable system (180 degrees view)
• Hoist to lower/raise spare tire, bikes, etc.
• 3 full length pockets in roof. Designed to fit surfboards, ski gear, fishing gear, etc.
Subframe
• Aluminum (treated for better bond)
• Permanent mount system over the truck flatbed
• Captive spring mount up front
• UHMW (heavy-duty, high-impact plastic) lined retaining plate
• Three shear plates inside the locker for additional stability
Storage inside/outside (all dimensions in the operation manual)
• Pass-Thru garage
• Extensive storage in subframe assembly (commercial latches)
• Custom made aluminium storage boxes (3x)
• Bed platform lifts on linear actuator for under bed storage
• Under seats storage
• Custom kitchen cabinets
• Shoe compartment
• 2x Dirty laundry bins (custom mold)
• Trash can pull out bin
• Flat platform in the crew cab back seat
Electrical & Heating
• 800ah (4x200ah) Victron Lithium Batteries
• 12/3000 Victron Multiplus Inverter
• 12/240 Victron Phoenix 240v inverter (for AC system)
• Victron BlueSolar MPPT charge controller
• Victron BMS, BMV, low voltage disconnect and related
• Victron CCGX interface
• Nations starter and Alternator second alternator system
• Blue Sea Custom breaker set up
• 1300 watts solar panels (LG mono x).
• Shore power hookup
• 2 outdoor 115v AC outlets
• LED lighting with dimmer
• Reading lights with two colors above bed
• 110V and USB plugs throughout
Heating
• Espar D5 hydronic heater, gas
• Additional heater thru the water heating system (Isotemp)
• Sure Marine Real air handler
• MaxxAir Fan
• Built in fan in dining area
Galley & Plumbing
• Indoor kitchen: 2x Induction Cooktop (Kenyon)
• Indoor sink
• GE Microwave
• 2 custom pull out outdoor cabinets housing sink and cooking gear
• Outdoor kitchen: 2x Induction Cooktop (Kenyon) & electric BBQ (Kenyon)
• Pull out for outdoor kitchen prep space
• Outdoor sink with custom sump pump assembly that pumps sink water into grey water tank
• Isotemp 6.4 gallon dual function water heater
• Isotherm drawer 85 Inox fridge/freezer
• 2nd fridge (Dometic CFX35W) in truck cabin
• 90 gallon fresh water capacity
• 40 gallon grey water capacity
• Water filtration system (3 stages)
• Natures head composting toilet in custom cabinet accessed via linear actuator slide out
• Full interior shower in entry door (shower curtain hangs from magnets in roof)
• 2x exterior showers
• Whale pump and accumulator tank and whale tubing and fittings throughout
Living & Sleeping Space
• 3x bench seats with custom cushions
• Queen size bed (78" East/West), (64" North/South)
• Multi layer European foam mattress
• Bed can turned into a coach by linear accelerator lifter
• Multi purpose seating area (seating, dining, computer work, additional sleeping space)
• Retractable dining table with storage for computer monitor. On sliders for custom positioning
• High End resolution monitor (27" BenQ) folded in the dining table for safe transport. Connection to attach to laptop/iPad
• WIFI router (PepLink Transit Duo). Bonding between two providers. Antenna (MobileMark 7-in-1)
• Custom waterproof carpeting (Chilewich). Quick dry to eliminate chances of mold and mildew growth
• Nature Head compost toilet. Pulled in/out thru linear accelerator lifter.
• Modified toilet to connect liquid to grey tank (reduces maintenance cycle drastically)
• Indoor shower with drain (2x), shower curtain, and combination faucet (spray/water flow)
• 2x exterior showers and a large exterior sink
oliklink
Assuming this is the original "Adrift" camper with your own truck? Here is the build thread: https://expeditionportal.com/forum/...-camper-build-adrift-motorhome.141578/page-25. Always LOVED the solid roof pop up design they came up with. Looks like you've really improved it and put it on a pretty rad base truck. GLWTS. Great rig.
Thanks for the kind words on the design and built. The F550 had already been designed. Additions were made to improve reliability, comfort, and experience.
Lucidless
Out of curiosity are you sure this is 11k watt hours? Thats 916Ah (you state 800ah), why did you install that big of a battery bank when you aren't running AC systems, and just using 12v appliances that draw low amps aside from the induction cooker?
This is the formula to check if its not actually 11k: Ah = Wh / V
oliklink
Voltage off the Victron batteries is 13.5V (+/-). I can run 4 induction cooktops, electric BBQ, microwave, computer + large monitor, blender, etc ... I also have a water heater (Isoterm) that can supplement the Espar D5 to heat water much faster.
When you travel up North during winter (when sun might not recharge the batteries daily), you can be more autonomous :)
(y)
IYKYK
Sick rig.
rawtoxic
Seems like a better value than a lot of rigs of this caliber! Can you tell us more about the electric bbq? That piqued my interest.
oliklink
Thanks for noticing how "fully loaded" this overlander is :)
Electric BBQ is from Kenyon, located in the outdoor pull-out kitchen. You also have the following outdoor: 2x Induction cooktop, counter space, sink, running water, 120V plug :)
Full description at: https://www.oliverklinkphotography.com/OffGridLuxuryCamper/
E
eugarps
Guest
Silly question but what fuel mileage do you see on this beast? It really is a remarkable design but is there a way to screen the large opening around the bed?
Thanks,
Bill
oliklink
Thanks,
Bill
On average I get 8.7 miles/gallon. When driving freeway, I get 9.4 miles/gallon.
I made a "bug screen" that is velcroed over the front opening. (image shown over the door opening) :)
oliklink
Link to an independent review by Jack Mac (05/05/2022): https://expeditionportal.com/overland-classifieds-2016-ford-f-550-custom-overlander/
Quote "Luxury overland vehicles have become increasingly popular during the pandemic as more people travel closer to home. Subsequently, this has led to long wait times for new builds and inflated prices for used examples. EarthRoamer is arguably the pioneer of this sector, producing vehicles well in excess of $1,000,000 (check out their $1,900,000 HD model for reference). The company’s LTI model, priced between $750,000 to $800,000, is arguably their most iconic vehicle, and is based on Ford’s legendary F-550. EarthRoamers are undeniably epic, but at almost a million dollars, they’re also very exclusive and inaccessible to the vast majority. However, fear not because today’s custom one-off luxury overlander is also based on the F-550, incorporates many similar premium features and modifications, yet is a third of the price, at $238,000."
Additional description and images at: https://www.oliverklinkphotography.com/OffGridLuxuryCamper/
SootyCamper
Is the 72gallon fuel tank custom or manufactured by titan or another company? I have not seen a gasoline tank that large on the market.
oliklink
Two tanks. (Ford built-in: 40 gallons, 2nd tank: 32 gallons). 2nd tank refills the first tank, starting the fuel pump from a timer.
I wrote a full owner's manual which includes: details on parts, how to operate, troubleshooting tips, etc ... The two tanks' description is part of it.
Goldenbora
