The speedometer info generally, in an older-ish setup comes from the driveshaft speed. In a 4x4 setup the data, electronically or mechanically, would be generated at the transfer case. So find the hole for a sensor or a cable in the TC!
Bumping an older thread. Does anyone know if you use the Quigley adapter doesn't that push the transfercase towards the rear more then if you used the ford 4x4 tailo section? On a van you have to shorten the gas tank to clear transfercase. If you use this adapter wouldn't you possibly have to cut the gas tank even more?
I believe this only affects the Gen 4 van. Right?Bumping an older thread. Does anyone know if you use the Quigley adapter doesn't that push the transfercase towards the rear more then if you used the ford 4x4 tailo section? On a van you have to shorten the gas tank to clear transfercase. If you use this adapter wouldn't you possibly have to cut the gas tank even more?
Check PM. I sent you email address of a guy who is interested.I have one for sale, if anyone is intrested.
