Family Adventure M1102 Trailer Build
Kingsize24
About three months ago we purchased an M1102 that already was a great starting point to slightly modify into a camper for us. We purchased it, and brought it home for the buildup. This is it where we picked it up in storage. Awesome starting point IMO, with GREAT bones.
Kingsize24
Once home, the first order of attack was to extend the hitch while also allowing for swappable attachment types, height, and retaining the hydraulic brakes.
I ended up duplicating the pattern of the original hitch slide mechanism. Functionally it's the same for the braking system, but now with the added adjustability I wanted.
Kingsize24
Once that was completed, I wanted to add an amber clearance light, so I found a NOS military LED set and mocked it up, drilled holes and got it temporarily mounted for fitment before removing for coating.
Kingsize24
Next order of business was propane. Since everything I cook with, heat with, and warm water with will use it, and we plan on being off grid for extended periods. I decided two big 30's would work just fine. Overkill at its finest. I used Aluminum and some stainless braces to make my mount and then started plumbing.
Kingsize24
Next was getting the passenger side awning mounted that also will have the annex for friends to use, or to use to eat in if bugs get wild somewhere.
Kingsize24
None of this is fully in for the final time. Just mock assembly of everything so I can blow it apart and paint and line-x things later. But I was able to pull the passenger side roll up doors for the .125 wall aluminum sheet, and get it in temporarily.
My tires that were on backorder finally came in as well, so I had them installed on another set of Power Wagon wheels and threw them on. They fit like they were made for it.
Kingsize24
And this get us to current. I worked on it some this morning to get this one lockable access door in. Measure ten times, cut once. ?
Now I need to put the windows in on the side in front of this door. They will be emergency exit windows on both sides with screens for ventilation and tinted.
I also have a Bush Company 270 Max awning to put on the driver side that I got from Midguard Adventure here in Texas.
Alloy
Nice build!
FYI... it's best to home run pronane lines so the only connections inside the living/sleeping area are at the appliance
Kingsize24
Nice build!
I'm actually taking the water heater out if there and redoing the propane connection to do just that. I only need one connection inside for the heater now.
However, thank you! It was advised to me also by the guys at B&W hydraulic that is remaking all new brake lines and hoses for me. That was their concern as well. I also bought a tri-gas monitor I will be installing.
darrylkd
