superbuickguy
So I might (actually, probably) will use this for my trip to Optima. It has water, an awning and a fridge.... oh and a place to sleep.
But I need to fix a problem. If I stay in the throttle too long, I get a check engine light and a reduction in power. I think it's because the new turbo just puts out too much air. Before I wind it back, I can change the fueling. Here's how
first, we need the PMD - the large heat sink is because GM really messed up with the PMD and mounted it to the injection pump, right there in the middle of the motor.... electronics do not like heat. So companies came to the rescue to relocated the PMD and add a cooler, the PO did those things.
Then the controller
So, the PMD has a chip in it that tells the computer what 'table' (to use current language) for the motor. There are 9 choices, 9 is the highest flow.... this is a 9
I took a chance, thinking the chip could be wrong for the larger turbo.... it was... a 6
New is on the left
One more step, next cut the front window out, reseal it, then start cleaning it up for its trip.... I tested the brake controller and trailer lights and they're good to go...
the only downsides for the Suburban. No satellite radio, I get about 13 mpg towing with it vs. 18 in the Colorado... honestly though, it's more comfortable
Then the controller
New is on the left
