2019 F350 6.2L 4WD build thread; HPI flatbed, ATO AterraXL composite camper, Carli/King, 37s, 4.88s, etc
RAM5500 CAMPERTHING
OG Portal Member #183
Yes, happy to transparently share.
--2 of the Tern Overland roof hatch LED's were intermittently working. Turn on the switch one time, 2 of 4 aren't working. Turn off, back on, still not working. Turn off, back on and all 4 working. My ATO dealer replaced all 4 regardless.
--My ATO dealer made a boo-boo when installing the new ATO entry door insulating panel (note; before this panel, while the Tern Wildlands entry door's window is tinted, that doesn't matter when you're inside the camper with lights on at night and changing into your bday suit; anyone outside gets a free show). There were no instructions from ATO and instead of searching for the few spy pics on ATO's IG, my dealer assumed (not a horrible assumption) that the insulating panel would go on the inside of the Tern exterior door where the window is, NOT on the inside of the Tern interior door. So they drilled into the inside of the exterior door, installed the little turnbuckle clips around the perimeter of the door, hung the insulating panel, shut the screen door on the exterior door/panel but the screen door wouldn't close...insulating panel is too thick. They call Mario at ATO, he says the insulating panel goes on the inside of the screen door. DOHP! So my ATO dealer orders a new $1300 Tern door, then they go to install it...wait, there are no door hinge pins which can be driven out and a door easily replaced. The Tern Wildlands door has hinging legs that are bonded to the camper shell, then riveted on to the camper. How the heck?! They find out that in order to replace the exterior door, they'd basically have to pry the door hinge legs off the camper and pray that they don't ruin the camper. ******? What kind of forethought did Tern have for people that need to replace a door? Apparently none. So, plan B is they filled in their erroneous holes with some special marine epoxy, smoothed them, then paying to have a pro vinyl shop apply white vinyl onto the white inside of the exterior door.
-I think I mentioned some of the other warrantiables earlier, but if not, first time I used the kitchen sink there was water dripping at one of the (non-genuine sharkbite) fittings. ATO dealer fixed up by replacing a bunch of them--apparently ATO has seen that some of these fittings have leaked on first use.
-For some unknown reason, on my camper (#002, but first production unit behind Mario's #001 prototype), they used thread tape on my propane lines. This caused the propane to leak out quite quickly. ATO dealer removed thread tape on propane lines.
-The rearmost handle(at rear wall) to the Lagun dinette table mount had the L-shaped handle end on the driver side, which prevented the table from swiveling towards the driver side a the handle was up against the Tern window shade (lower) roller. So, this handle was swapped to pass side and now the table can actually move. <hopefully now they are testing systems a few times before camper delivery>
Agreed with chadx on the R-value/camper weight debate. Regarding Aterra XLF(flatbed), ATO had initially informed me; "The walls with their coating inside and out are 5/8” thick with R-4. The floor is 1-1/8” thick R-6. The tapered and flat parts of the roof are 9/16” thick with additional insulation yielding R-8. The key to cold weather comfort in this shell is minimal thermal bridges and the 12600 btu Truma Vario [propane] heater."
Note; ATO's site still says "The well-equipped camper is suitable for all seasons..." After some winter time in it, I'd challenge that statement. "Suitable" is the key word. Sure, the Aterra can be used in all seasons, but it's interesting other camper companies with thicker walls like OEV and TotalComposites state "3 season camper." That's more accurate IMHO.
@chadx, curious on your OEV CampX, for your 20lb propane bottle, camping in winter, having the interior temp set to 50degF let's say, how long will that propane bottle last you?
1150lbs dry supposedly; https://atoverland.com/pages/aterra-xl-flatbed-camper
Add in 30gal water (249lbs), some of the available options, and some "buffer" pieces between flatbed and camper in case you need to add a smidge of cabover height over truck cab, and you're at 1650lbs pretty quickly.
Agreed with RAM5500 on all the windows. I too have learned this firsthand. The 5 Tern windows are nice in that they prevent a light/bright interior, but in the middle of the summer I was keeping all the blackout shades up. Light, but also solar heat, infiltrated the camper, and the small Maxxair dome fan (nor the Tern hatch, or opening a few windows) could evacuate all that solar heat quick enough. So now, even in winter, if the camper is outside, the blackout shades are pulled down to keep the camper interior more thermally stable. Note; I had thought about having the tint shop add some 3M Ceramic (light shade) tint to the interior of these windows. That has helped dramatically in the truck and all of my other rigs.
Note on condensation; I still have NOT come across any condensation (walls, windows, etc), even with 18degF exterior ambient temps and the Truma propane heater running between 48-65deg, and 1 human and 1 dog inside. I am impressed with that.
Aluminum strips, used to bond cabinetry to, are on the inside of the "lightweight fiber reinforced thermoplastic honeycomb composite" cabin. I can also see a few spots of Coosa inside for bonding items to.
Yes, the honeycomb panels butt up against each other, and then aluminum cap seals the corners/edges (like TC's extrusions, but different). So, should be no thermal bridging as the aluminum caps are on the outside of the honeycomb panels.
Thx on steps @kmacafee. Standing up on rear tire IIRC was regarding my gray G-Wagen build. I like those mast steps. How are you supporting them on the backside?
My stairs under my dog platform take up less than 2" of "depth," so not much room at all.
Thx for your thoughts Scott (@sg1). See my info above.
Thanks for the detailed reply.
Hopefully everything gets squared away soon.
I am going to inspect my door more closely tomorrow when I work on finishing my new counter.
I remember when I was installing it, thinking, how the hell could this be replaced if I ever had an issue after gluing it in place.
I’ll inspect and report back my findings.
FWC the white thread tape on my propane stuff too and it leaked like hell.
Longgg story short, there is a YELLOW thread tape made for gas and after I took it all apart and used that, zero leaks. FWTW
mk216v
Der Chef der Fahrzeuge
I am doing to inspect my door more closely tomorrow when I work on finishing my new counter.
Certainly!
My ATO dealer, Oregon AT, is awesome!!!
LMK what you find with your Tern Wildland door. And don't F it up, cause you'll be cussing for months if you have to replace it.
Yeppers. Not a great install design at all. :(
My thread tape on propane line fittings was yellow, but it was leaking. Perhaps it wasn't installed properly, but some of my BFF's in the industry said a hard HELL NO to any thread tape for these fittings, my ATO dealer said the same, and then Mario agreed, so it was removed from my camper. So <hands up in air>.
Victorian
you have the euro door. Fairly easy to just take the door out. But dont have you have too. Adjusting it will take a while
kmacafee
The sidewalls of my flatbed are pretty thick but I added an aluminum backing plate as well. No issues over 4 years.
mk216v
Engine/trans skid and rear diff skid fab is complete! Anthony at Bellfab knocked it out of the park IMHO. He says they'll start production soon, after maybe a few small manufacturing tweaks first. More vehicle models to come as well apparently.
Front engine/diff skid is 1/4" aluminum, all 3 pieces weigh ~30lbs which is pretty damn good. Threaded inserts for ease of install/removal (for oil changes, etc) w/ SS hardware. Optional security hardware for anti-theft of cats and such (my cats were already robbed, hence another reason for this plate).
Rear diff skid is 3/16" steel, CAD designed and CNC cut, and installs without having to drain rear diff fluid--just bolts on using existing Ford hardware.
mk216v
Damn, those look good. Really good! Happy to see some quality ones on the market.
Yeah, he's an incredible fabricator, and also just a heck of a nice family man and community supporter too. I actually enjoy giving him money!
Finally some quality options--surprised it took this long. But it's also good to see more love for the full size trucks, which don't feel like full size trucks!
Macfly
That looks like a great set of guards, don't see them on their site yet, but I'd definitely be in for a set for my F350.
mk216v
Anthony at Bellfab is working on a new website he said, but he's trying to get these Ford SuperDuty skids on his current site for the time being.
Said he's going to offer these at an introductory price for a little bit of time. His normal price for the engine/trans skid kit will be $648, but intro price will be $573. For the rear diff skid, because of all of the welding required, normal price will be $148, but intro price will be $118.
Send him an email if you want to get a pair of these, as he just released confirmed fitment on '20+ 7.3L Godzilla as well, so I bet he's going to sell quite a few of these quick. anthony@bellfabrication.com
Edit; up on Bellfab site now https://bellfabrication.com/product/ford-superduty-engine-transmission-skid-plate/
07megacab
Would you mind taking a measurement of the interior height of the sleeping area of your aterra? From the floor to ceiling if you can. Does yours have the Froli system? If so, how do you like it?
Ninelitetrip
Added benefit.
  • Optional security hardware at +$30 provide extra security to catalytic converters
Chadx
♫ Offroad, again. Just can't wait to get...♫
Added benefit.
Wouldn't be a bad idea to add the optional $30 "Stainless security torx hardware" rather than the standard "Stainless button head hardware". A bit less likely a "cat burglar" will have the security torx bit along. They don't say what the standard button head hardware uses, but probably hex? The skidplate coverage is the same, though, but that alone complicates access to the cat.
V45W_Proto2.5
