I’m well aware and I think we have a solution. But I won’t buy a new vehicle without LED headlights and BLIS is packaged with them on the 23 unless you go cab chassis, and Ford doesn’t offer a crew 160WB cab chassis.
If anyone wants to know more about the latest on this, checkout the Ford bulletins here related to box removal
https://fordbbas.com/bulletins
Not sure how Fords are, but check into adding the OEM headlights after the fact, so you dont end up with unwanted options
Example: I ordered my Ram in SLT trim because LED headlights were mandatory, same as you...
Long story short, found out after the fact, the Ram LED headlights, bolt and even plug right into the place of the OEM halogens, and they are fairly inexpensive at that.
I could of saved a decent chunk of change with my purchase adding the OEM LED Headlights after the fact rather than ordering the SLT trim to get them.
NOTE: No clue if Ford is the same, and if not, how much work it would be to add them after
