YOLANDA...My Turbine Princess build 03 7.3 E350 pop top 4x4
ITTOG
Gotta keep some chrome or my flairs will look odd..
Hydraulic jack.. hi lift to spread it apart.. and hours of using a planishing hammer to get it close!!
It’s not perfect.. but a Lund Visor should hide that ;)
That is taking DIY to a new level. It looks really good.
Sent from my Pixel 7 Pro using Tapatalk
RVflyfish
Because trout live in beautiful places
After seeing the pics with the roof caved in, I would never have believed you could get it that straight again. Well done! You bring new meaning to “where there’s a will there’s a way.”
Are you going to add an intercooler now that you have the ‘08+ front end?
TyVanosaurus_Rex
So happy you're able to get your rig put back together! I can only imagine how much that sucked to see - but the rebuild is looking GREAT!
Curious about your spare tire carrier - Is that a product, or something you crafted?
Looking for something similar for my van as I don't quite have the funds for a fancy 3k+ aluminum swing-arm/bumper mounted spare tire display :ROFLMAO:
wanderer-rrorc
Yuuuupp.. baby steps thou.. she’s going to need glow plugs and the next year so I figure while I’m in there I’ll go ahead and put the super duty in a cooler Spyder valve and then I can do the intercooler piping. Right now I’m kind of tired of spending money on there and I want a Drive her!! first campout is planned for the rings and coffee Macedonia Ohio. We’re staying at Mill Creek Campground on the weekend of 26 August.
wanderer-rrorc
It is a Ford factory rear spare tire carrier from a 2003 and newer van. I got it off of craigslist for 40 bucks and the guy gave me two other ones that are pre-93 because of a different hinge design that if somebody ever gets close and needs one and can use one, they are more than welcome to have it.
Check your local junkyards check car part.com check rockauto.com they may have one listed and scour the Facebook marketplace and craigslist the van guys horde everything !!
wanderer-rrorc
Oh, and the nice thing is is both the box and the spare tire carrier amounted to the door so in case of emergency, we can go right out the back doors without having swing arms in the way!!
wanderer-rrorc
So today’s update I picked the Bumper material up earlier this week and had some ideas on what I wanted to do.
Ran out of time and daylight tonight but I got everything bent where it needs to be.
I need to do a full weld.
I’m probably going to put a filler piece in the wheel well and trim it to match the arch but overall I’m really impressed.
The van now has two 6000 pound receiver, hitches welded directly to the frame rails and including the 8000 pound Curtiss front hitch
The bumpers 10 gauge mild steel that I’m going to probably make some upper hoops for later right now I’m just enjoying the clean look.
The plan is to paint it with hammer tune, either black or dark graphite. Hammertone paint is like kind of a mix between raptor liner and powder coating. It’s very very tough seems to be pretty scratch resistant, but you can do touchups easily from a rattle can without any significant Pattern deviation so it blends very well
Still got to get the windshield wiper assembly back on the Cowell on it. Turns out the part I bought was the one that’s not broken so I just ordered two windshield washer sprayers I need to trim a little bit of the caulking. All of the solar was put back in all of the interior. Electronics has been put back in . She’s ready to get the nut and bolt and tires checked and take a trip.!!
wanderer-rrorc
Here’s a pictures of the new glued on solar panels.
Iwent from 200 watt Renogy (broke one still WOEKS) to 380 flat panels.
I’m pretty impressed with them so far I haven’t had much of a power load in the van so I don’t know what their actual max charging rate is and turns out that apparently my house batteries are in great shape because they did not lose any voltage sitting in the garage for 47 days.
Still got to put some things back together get some things trimmed. I did get the vent visors installed and the windows tinted.
I forgot to mention I’ve got to cut a hole in the new bumper for the intercooler and so I can reach in and pull the hitch pins out some ideas for some brush guards but right now I’m just gonna go with the clean look that we have.
ITTOG
Where did you buy the solar panels from? Do you have a link?
wanderer-rrorc
Amazon and don’t buy them!!
I just replaced them with 300 watts of glass Renogy panels.
Those panels over 80° ambient temperature they were only putting out like 15 or 20 W of power. So anything over 60° outside they basically were worthless. ..
wanderer-rrorc
Got her out for her first camp out. She did really good getting about the same fuel mileage as before no weird, whistles, or wind noise pretty happy with how everything worked out
Definitely needed to upgrade the fog lights and readjust the headlights so I put the big 9 inches back on and I really just didn’t like how they look so I’m got two pair of the rectangular ones like I have on my F150 to mounted low and then I’m gonna put you up on the windshield. I’m just waiting for those amounts to show up.
wanderer-rrorc
Last Riggs n coffee yesterday.. got the nose art applied… using a cleaning and heat to make it stick!
wanderer-rrorc
Been a minute since I posted. Took her to Drummond Island and had an absolute blast. Turns out that’s a little rougher than what the vans designed for and I felt like I was abusing it.
Just ordered new wheels and tires after coming back from both Drummond Island and the Summit Overland adventure and Daniel Boone, Kentucky
Black rhino, Sentinel cobalt blue wheels zero offset and the same size KO3 as my Nitto ridge grapplers
So far they’re quite a bit quieter definitely a stiffer sidewall so I’m playing with air pressure and I have driven about 100 miles and I’m pretty happy with them so far haven’t had a chance to drive them in the wet …
wanderer-rrorc
Also put in a new dual tennis fans to help with the air conditioning and a digital programmable thermostat that I’ve been playing with. You can tell when the fans kick on the air conditioning gets about 20*
colder inside.
V45W_Proto2.5
