2016 Chevy Silverado LTZ Z71
D45
I'm thinking it's a trans temp sensor that's triggering the P0700 code
With the trans temp visible on the dash, the displayed temp will bounce from 79 degrees to 122 degrees, occasionally .......and not remain constant
D45
I never realized this transmission doesn't have a fluid level dip stick, makes for checking fluid levels impossible
D45
Installed today
GM OEM gas cap:
PN # 22921365
Purolator One cabin air filter:
PN # C38173
Purolator One engine air filter:
PN # A45314
D45
I also need to look at the TPMS sensors
3 out of the 4 read normal PSI, one is reading 12 PSI lower and the actual PSI is spot on with thr other 3 tires
Bad sensor? Low battery?
D45
I think my trucks TPMS sensors also need to be replaced
If I am getting new tires this fall I may as well replace all 4
Does anyone know the frequency of them? My search shows two variants for my 2016
ThundahBeagle
What? I have a 2014 that has a transmission fluid level dipstick. It is on the passenger side in this generation. Even if you don't see a dipstick grab handle, it is usually there. Look for the same tube to run up the side of the engine but with a simple, unmarked, cylindrical stopper with no "gear" or "trans" markings on it.
They camouflage them sometimes, in an effort to keep the laymen away from it, but they still need a way to check it at the dealer
D45
You have the 8 speed transmission (8L90) in your 2014?
8L90 has no dipstick
You likely have a 6 speed transmission
ThundahBeagle
No 8-speed. I do have the 6 speed.
If you are beyond warranty, you may want to look into getting the dipstick and tube off a 2016 Camaro.
D45
My truck is part of that recall, I haven't taken it in to get it looked at, but I haven't gotten any kind of code or issues either
Sent from my moto e6 using Tapatalk
Anyone confirm if the brake booster vacuum is covered under a safety recall?
I belief my truck is affected but online search with the VIN says no recalls
D45
I never buy new, so that is possible
At low RPM (low vacuum?) I'm starting to have a somewhat routine braking issue
The belt driven vacuum pump on the block seems go be easy to access and repair. Part is under $200
D45
Also found a video online showing the updated vacuum pump and the new internal baffle
D45
Rock Auto has the new design AC Delco pump for $112
I'm fairly certain I could install it myself, but my concern also would be knowing the pump is actually needing replacement
D45
I ordered the pump, a new serpentine belt and a new pump stretch belt......$151.28 for everything is better than a $550 and $728 quote
gp01
