Some changes were made while coming home. I installed my TRD charger that I had for 4 years and a month after that I blew up the automatic transmission
So instead of fixing a $900 rear bearing, I converted it to a R150F manual transmission. Before installing the new transmission, I took off the stock headers and replaced them with a used, but modified TRD headers.
Then I installed the flywheel, clutch, & clutch plate
Then install the R150F manual transmission and tcase
Then installing the pedal assembly, clutch master, and finally the wiring
