The Wanderers build
superbuickguy
Yes I saw it and it looks nice. Was just speaking in general terms. And it all depends on how easy you can see that screen etc. Definitely many different ways to accomplish your goals however. What you have done thus far looks amazing.
I have a couple projects that will get hidden radios because I don't want to mess with the aesthetic of the current dash (50 Buick Special) - and it works for others... glad you brought it up because I know a lot read this for ideas for their build.
Kingsize24
Absolutely! I enjoy seeing it too. And I do the same. Browse and get great ideas from different builds.
superbuickguy
Rear bumper
light install. mark holes using the gasket center from the lights
then mark
with the lights set in place
I decided I wanted flat lights so ordered those.... seems like a risk to leave them floating in mid-air on an otherwise indestructible rear bumper
sometimes I use the tig to 'wash' the edges to make finishing easier.
then spent the rest of the evening grinding until my arms were numb
at least rough grinding is done, now to make them look seamless.... tomorrow.
superbuickguy
supplies for the next steps
as unbelievable as this is going to sound, I found another at UPullit. Was free (even better)
time to start mocking things.... sending the panels down to my upholstery guy in the next day or so
making those patterns
then the rear window, where, as is typical, I got stopped because I need to replace the cable
ah wiring, I missed it soooo much
superbuickguy
annoyed at my USPS wage thief (after all, if you take a wage for a job then don't do it, you're a thief).
Porch is 50 feet from the driveway - he left all the boxes of electronics in the rain in the middle of my driveway.
and yes, complaint time. UPS then put the even more expensive stuff next to it. smh. ah well, I think I got it before it actually soaked inside the box.... but really?
anyway, my stuff arrived Pioneer stereo, Kicker speakers, Pioneer amp, Kicker down-firing subwoofer
oh and CB
I have a HAM radio already but HAM is part of the package
it's like a soggy Christmas came early
the UPS guy gets a warning from me on next delivery - he's been really good so far, but that .... yeah.
superbuickguy
decided to continue my annoyance and work on the tailgate.... it worked, I got more annoyed
once I got the sweeps in place, the window had trouble going up and down (the gear slipped).... so more parts on order.....
up soon is the installation of this and probably a storage tank
and start planning for the electronics install. CB and HAM radios... I think I'm going to put a shelf above the window and install them there... makes it easier to hear them and keeps cords and stuff out of the way
it seems everything is bigger then expected.... including the amp. The suggested putting it under the dash... um, the only way that is happening is with explosives
set the new seats in place
so I could test-fit the subwoofer
the issue here is when I put the 'camper' on it, I need the floor space to remain clear or flat.... which leads to the next issues which are where things like a 10 gal water tank is going to go....
This truck is strange in that it uses the seat tracks and such from the earliest squarebody Blazer. However, these seats came from an 84.... but for some reason GM went back to their original design when they built my 86.... just weird
anyway, more soon.... thx for watching
superbuickguy
moving back to the blazer from this
I need to find a side panel.... not sure if it's even possible but I bought my wife a 3d printer for her birthday, my hope is I can either use it or convince her to print me out a cover
then grind for a minute
then work on installing the headliner
first, run wires to power CB and other stuff
and start fitting
the absolute hardest part is lining up the screws to hold the uprights
then start working on where the seat is going to land
throw in a fix for a snafu (burned the circuit board)
and a billion other things and there we go... incremental gains.
superbuickguy
some days I wonder why bother...
to remind, I bought a new worm gear for my rear window
then took it apart again - note how the motor is low?
it hits the window...
eventually got it back together (but the glass doesn't go all the way down because the cable is in the way...
then figured I'd do something easy like aim the headlights... easy
then, since it couldn't get worse, I simply went back to the window I was avoiding from before. for unknown reasons it slides back and out of the front track while going up and down.
the other side works fine so the assembly is right but this side doesn't want to stay where it needs. I may get clever with a hammer tomorrow...
superbuickguy
started a fire in the shop before I left for work this morning so I could paint tonight....
start with the top by putting adhesion promoter on
then clean
Not sure I'm a fan of SEM liner
and I get it, anyone else looking would think it's great.... and it is, but I wanted more texture
not bad
also needed to fix this - it keeps the door latch from working if the window is up
test fit
now with epoxy
now another cherry section in the fire and it should stay warm enough to touch tomorrow. I was taking paper off (as recommended, but making a huge mess - I'll use a razor blade to separate the seal and tape from the bedliner
ExpoMike
Yeah, Raptor Liner would have been my choice. You can adjust the texture with air pressure and it ends up more of a semi matte finish instead of glossy.
superbuickguy
it was completely wet last night, seemed to be drying down to a more matte finish when I checked this am.... It was a comedy last night, first step was repair where I broke an air line when I was doing bird removal earlier this year....
superbuickguy
but wait, there's more
love it when I can find 1 of 4 bolts I need
epoxy epoxied
seat belts arrived and are rewebbed
then some assembly is required
so there's a rubber seal, it needs to be pulled over the edge
or sealed with great stuff (when the rubber tears)
need to apply heat and it'll seal
in other news, rear bumper is now painted and assembled
now comes the most annoying part.... the waiting for parts... missing one clip
superbuickguy
for those wondering who inspires me.... the funny part of this - he went from a Iveco (or similar) truck with a box to a Renault 4L .... I just didn't go quite as extreme either way - I have a 26 foot class A motorhome, then Suburban, now Blazer.... but still....
