My Fuso4x4
BigSkyBrad
6500kg / 4 = 1650kg. -- but it is not that simple.
I have already been through the certification process to convert to single rear wheels in the UK. The UK uses the same regulations as the EU, because trucks from UK travel through Europe and vise versa.
Upon certification, a new weight plate is issued for the truck. The weight plate is the plaque that shows the GVM (MAM) and the axle load maximums. My truck has the plate attached to the rear wall in the cab behind the drivers seat - yours should be in the same position because both your truck and mine were built in Portugal.
The front axle weight needs to remain at 2800kg. The rear axle needs to be down-rated to 3900kg to correspond with the minimum tyre load rating that will maintain the 6500kg GVM, and the 10,000kg train weight (for towing up to 3500kg). So, 2800kg + 3900kg = 6700kg - this is good as there is 200kg spare 👍. The new weight plate will show the rear axle weight to be 3900kg.
The minimum tyre load rating for an axle of 3900kg is 131 - luckily this is the rating for the tyres you have spoken about, Radar Renegade 37x12.5R17-131Q. The rating of 131 corresponds with 1950kg -- 1950 x 2 = 3900.
This means that the wheel also has to have a minimum load rating of 1950kg to be used on the rear axle. For the certification process, the wheels will need to have been certified by the manufacturer (TEJ) to have a weight load rating of at least 1950kg per wheel to operate on European roads. You will need proof of this certification.
I hope all this will translate well to Spanish for your understanding. Converting to single wheels is an expensive exercise to get wrong.
BigSkyBrad
Do you know what weight loading TEJ have certified each wheel for (in kg)? I would be interested in buying a set of wheels.
They are 17 x 10, correct? Do you know the offset (ET in mm)?
Ferjablito
I don't have that information, but you can try to request it, send him an email
Ferjablito
Well, we continue to advance on the outside little by little, perimeter roof racks or roof racks of the box, and rear wheel rack
  • Like
Reactions: mog
SkiFreak
Crazy Person
Is your spare tyre/air conditioner frame only mounted at the bottom, or is it attached to the camper body too?
Ferjablito
Well, the idea at first was to anchor it only to the subframe, as the manufacturer Urocamper did in one of my previous exhibitions, but finally I listened to the welder and we are going to anchor it to the perimeter reinforcement of the box at 3 points to avoid vibrations.
gator70
Thinking about spare tire choices. I have one planned. If I carry only the rubber tire on a 2nd will that be helpful? (Its about side wall damage)
Ferjablito
You can easily carry a complete wheel and a tyre, perhaps I should have opted for that solution, the drawback is having to change the tyre when the problem occurs. And it is not a huge added weight either, the important thing is that it is well anchored.
Ferjablito
I'm making very slow progress. The plumbing, heating, etc. connections are almost ready. Last week, the access ladder was anchored.WhatsApp Image 2025-03-20 at 11.27.18.jpeg
SkiFreak
Crazy Person
That looks very neat, but it's a huge amount of connectors! :unsure:
Tracking down a leak in that setup would be a fun exercise.
DFWSFO
