Heat Recovery Ventilators
Trail Talk
Really appreciate hearing from someone having experience with Lunos in an RV application. Your covers are slick! Could the Lunos cover rotated to a similar cant back?
yamaha225
I've used the LUNOS HRV a bunch & think they are a non-negotiable item for anyone 3+ season camping. I don't but if you have any sort of combustion happening inside the envelope of your camper perhaps even a critical safety item in the winter.
Biggest plus to the LUNOS for me is it's modular so I can make my own plenums and its 12vDC.
They work great but need a bit of modification to work properly on a mobile application IMHO.
The inside air exhaust / fresh-in outlet is ok if you have a dead ended cabinet. The exterior in/out cover isn't optimized for road speed in the rain as they are meant for a stationary application. I disassemble them and print my own interior and exterior plenums. On the outside it's pretty simple, a basic cover splitting the intake/exhaust airs & canted to the rear so wind underway doesn't venturi rain water back in. On the inside I print an end cover with a magnetic plenum for ease of assembly and that directs the intake fresh air through an adjacent bulkhead. The cabinets are vented so the exhaust air is pulled from inside the camper away from the fresh in. Hard to separate the two flows outside but you can't win them all.
Happy to share the STL files with anyone who wants to print their own. I use ASA for strength and UV stability but if you sanded and painted the exterior plenum PLA would be just fine too. Tree supports to avoid warping the flat surfaces.
View attachment 867091View attachment 867092View attachment 867093View attachment 867094View attachment 867095View attachment 867096View attachment 867097
Is that the Lunos E2 or EGo?
Trail Talk
The outside vent cover/baseplate has to line up with the internal (insulated) ducting. I believe the direction/angle of down facing exhaust can not be changed.
As Blackdogvan noted, would there be anything in the way of rotating the entire unit?
yamaha225
That’s why I asked whether he was using the E2 or EGo. I have the E2 in my house and there’s nothing stopping you rotating them however you want. It looks like that’s the EGo though which has two sides and I could see it being more important which way it’s oriented. Still not sure it would matter much though.
Blackdogvan
I use the EGo version. No reason I can see why it can't be rotated +- 45 degrees.
SootyCamper
To echo the use case for the "suitcase" style units. I attended the allrad show in Germany last may and found this unit by Bayernluft. I too am looking for cold weather passive ventilation, so seeing a company on this side of the pond like Pioneer building basically the same unit is pretty neat.
As far as use case for RV use? Well, Bimobile is one of the largest players in Europe and wouldn't be placing these units in their campers if they fail. As pictured below they've attached it to the entry door on that specific camper. Utilizing this dead space on the door is great if you arn't planning on having a window in your entry door.
Heres a link, they offer simple manual units all the way up to humidity sensing wifi enabled units:
BayernLuft
Trail Talk
BayernLuft
Excellent, bookmarked for a session with Google Translate. Also looked at Pioneer site but couldn’t find 12v offerings?
Trail Talk
A Google translated excerpt from the Bayernluft website re camper applications. Interesting points; "adds around 12 cm to the wall" (5 in) and "there is no minimum wall thickness".
Even in well-insulated vehicles, moisture must be ventilated to prevent condensation in cold environments. If ventilation is carried out without heat recovery, a lot of energy would have to be used to reheat the fresh air. This is where the small decentralized ventilation unit with a heat exchanger helps, which "recycles" the energy from the used air and thus preheats the fresh air in winter. In summer, the heat exchanger blocks the heat input caused by ventilation. However, please do not confuse the function with an air conditioning system, which can also remove the heat that has come in through solar radiation or heat transmission.
The main area of application is typical ventilation for moisture protection, i.e. to prevent condensation on cool parts of the outer shell in cold weather. Please note that this requires lower air exchange rates than for nominal ventilation. Of course, with every cubic meter of air exchange, CO2 is also ventilated, but there is only a dilution effect here and we do not want to give the impression that values of even close to 1000 ppm could be achieved in residential areas. If you do not have ventilation, our device is a huge benefit, but if fresh air is the main priority, then you should think about a larger device. Our device will not be offended if you open the window when necessary. This can also occasionally be necessary with very large vehicles or particularly high levels of moisture emission. In cold weather, our device has an enormous dehumidification capacity with a maximum power consumption of 6 watts and a comparatively low weight and space requirement.
The base body measures 30x40 cm and adds around 12 cm to the wall. Two rear pipes with a diameter of 50 mm lead through the cabin wall to the outside. There is no minimum wall thickness, but the device must be mounted in portrait format (no horizontal mounting and no landscape mounting). If condensation occurs in winter, this is also transported away via the shortest route through the lower pipe to the outer pipe cover with drip lip.
Thanks to operation with 12 volt direct current, a power supply is usually not required, as it can be connected directly to the 12V on-board voltage. Voltage fluctuations between 11 and 15 volts are tolerated. For 24V systems, a conventional voltage converter to 12V is used (e.g. Victron 24/12-5). The fan motors are padded with foam to protect against vibrations and have been doing their job in expedition vehicles around the world for many years.
In issue 50 (02/2019) there was already a detailed user report in the Allradler magazine
www.allradler.com
Our devices were also reported on in the specialist magazines Caravan and Wohnmobil in 2024
Blackdogvan
What is your experience with this unit during sustained sub-zero weather, any obvious condensation on the outside?
I've not seen them in action in brutal cold so I can't say for sure but I think it would depend a bit on how you installed the unit. If the exchanger matrix is really close to the wall opening then the warm moist exhaust air will freeze it for sure & this is a common issue with residential HRV systems. If extreme cold is your requirement I'd consider installing the matrix as far inboard as possible, even running the two flows separately through some ducting. Either way you should consider how the system will manage the frost when it melts again so you don't get drips. To be fair I've never given this issue a lot of thought but I will now.
Trail Talk
A good example from a recent trip (Ice Ice Baby 2025) shows the ice that built up outside our bathroom exhaust fan. The small computer-type fan runs continuously and makes the bathroom compartment an efficient "drying room". Ice usually forms during especially cold temps but hasn't yet interfered with the fan's operation.
calameda
Anyone know what ATOverland is using on the ATerra? They describe it as “fresh air replenishment system with condensation removal”, not as HRV, and appears from video to be flat and externally mounted. I assume its more than a low power computer fan in a box for $1200, but??? :)
calameda
Im just bumping my question here, no responses. Am genuinely curious.
Trail Talk
Here is a look at frost build-up on the Bomar roof hatch when it gets really cold. A lot of it is simply breathing 😮‍💨
V45W_Proto2.5
