New kid on the block! AWD Transit with composite camper AEONrv
Steve_382
Just as an alternative for people who might be interested in a truck... I keep my large 29+ bike, 6 big crates of stuff, plus tools and drinking water behind the front seat. Used to be a rear seat (not full size) until I removed it. It's all easy to access. Of course that won't work if you need to put people back there...
I like having bikes inside, too... although mounted on the back, well secured, and covered would be acceptable.
I thought that would work also, but I took my newer 29" Large Trek MTB with 30" wide bars down to my Ford dealer with the front wheel removed and couldn't fit the bike in the back seat. It was about 1 or 2 inches too long to get the doors closed. If I wanted to remove the rear wheel also, no problem but I don't want to have to mess with the chain, etc. each time I ride it. Road bikes fit no problem as they are about 10" shorter than the MTBs. My old 26" wheel Trek 8000s would fit easily also.
rruff
I'm guessing you flipped the fork/bars around? I had to lengthen the cable and brakeline to do this. Just barely fits, with the steerer almost hitting the ceiling and doorframe just above the door, and the rear tire right on the door. It's immediately behind the seat, BTW and elevated, with the front as high as possible so I can get the bars near the ceiling in case I have a passenger. If your stem is short and bars swept back, flipping the fork around may not help much... I have a 120mm stem though.
Steve_382
My Trek has a bump stop that won't let you rotate the bars 180 degrees. Grrrr
Steve_382
If the forks won't hit the downtube, can you remove the stop?
Hadn't thought about that, but found a video where they ground off the stop on the knock block. Looks like my fork would still hit the frame for sure one direction, but maybe not the other way. Also, it looks like a pretty straight fork and not sure how much I would gain if I was able to flip it 180 degrees. It's a Trek Top Fuel 9.7 about 4 years old. The guys on this video said the new ones don't have the knock block, so maybe reason to get a new one. Ha, ha.
joedenbon
To Davidalanhart, Corgi_express, Xrunner and any other AEON RV owners, we are interested in hearing your experience with AEON: What are your overall impressions? Any surprises - good, bad, or indifferent? How about warranty/maintenance experience - any experience good or bad? Are components easily accessed for service and maintenance? I'm also wondering about the control panel - if that system goes down, is there a back up? (I've heard nightmare stories about multiplex control systems malfunctioning and nothing in the RV works when it fails.)
So thankful to have found this site and for any replies! Our membership for the FB AEON Owners and Explorers group has been pending for over a month, and we are eager to hear more about AEON. (Nothing against the FB group, could be b/c we don't know what we're doing since we don't use FB 😊) So again, many thanks!
joedenbon
Just a quick follow up...I was finally approved for the AEON Explorers FB group, and have been happily bingeing posts there...finding answers and insight related to my questions and looking forward to owning an AEON some day! Thanks again for this site and your help.
Zybane
Has anyone cross-shopped the Aeon with an Ekko 23B? I'd like to keep my purchase capped at $200K which is entirely possible with the Ekko, but may stretch it if the Aeon is significantly better for your typical Overland/off-road camping.
gator70
This is based on a Sprinter AWD system. Not very capable. One guy tried to do some "light" stuff and the rear differential cover made from tin got bent. All the fluid came out on the trail.
Same driveline, Sprinter weak point offroad
Zybane
This is based on a Sprinter AWD system. Not very capable. One guy tried to do some marginal stuff and the rear differential cover made from tin got bent. All the fluid came out on the trail.
Are you saying the Transit AWD system is much stronger? Or is AeonRV upgrading the driveline?
gator70
I'm guessing it is more about ground clearance and ability to take 37" tires
Also the bounce from a "fully weight loaded rear axle" can contact imbedded rocks on the offroad roads.
Find a more robust platform, that is underweight and can take 37" tires
The AWD is made for snow and slippery roads, not overland travel
Also this platform is missing articulating subframes designed to allow a vehicle's chassis to flex and twist independently of the main body
rruff
If going offroad, definitely the Aeon. I'd put a little bigger tires on it (VC says 265/75r16 (31.6") work with that lift vs 245).
Better build, much more powerful engine, better ground clearance, cheaper maintenance... but less room.
Aeon would still be lacking offroad compared to a truck chassis, but may be fine for your needs.
gglockner
I did. I like the Aeon a lot but the bed situation was a deal killer: the split beds in the Sprinter EKKO fit our needs much better. I also needed a vehicle within a 6-month period and the backlog for the Aeon was too long. Also, my spouse was not a fan of the Aeon entryway restroom.
After extensive upfitting by FreedomVanGo, the EKKO is a very capable vehicle. But there is a lot to like about the Aeon. If the Aeon had a shorter lead time and separate beds, it would have been a very close decision.
I was able to see them both at Overland Expo PNW last June. It's great to see them both live.
Henrybrowne
