OVRLND CAMPERS ONLY : Post your OVRLND Camper build here or a link to your build thread to inspire others!
dirtnsmores
Very cool project! I did the full length doors on my Tundra, and secured the passenger side against the side of my kitchen. During the process I looked at doing what you have done and thought it would have been cool!
The interior build looks great. Did you do that all yourself?
locrwln
Beautiful truck man! I just got back from a
1500 mile trip to Utah and my FGT did absolutely fantastic through desert and snow. What a trip that was. Mine is pushing 200k miles. Where are you at on the miles?
Looks like a great trip. It’ll be a bit before we get to put ours through the paces as I’m tied up with work for the next five months. Ugggg.
Im at almost 223k miles.
Jack
locrwln
locrwln
Here are the interior framing pictures. I used a spool gun, so my welds aren’t as clean/nice as OvrLnd’s TIG welded joints.
Let me know if anyone would like anything else.
Jack
aaaslayer
Jack
You did an awesome job. What welder are you running and spool gun? 110v or 220v?
aaaslayer
Love to see people take on the custom route to frame up and do their own doors. I need inspiration to do mine as well. Been drawing out some ideas on how to add bottom half barn doors to my existing barn doors. I wish they offered this from factory.
dstefan
Jay used to offer the lower halves for the barn doors, but I dont see it on his options list anymore. Did he stop offering those?
Regardless, I’d be surprised if he wouldn’t make. set for you, if you wanted.
Morning dstefan,
Jay stopped doing it in shop, but you can still order the lower half doors and do the install yourself. I am attaching a link to the instructions...... Jeff
dstefan
More Dust and Smoke Control Mods:
The passive Positive Pressure Vent has worked pretty well for me, but over time, I have had a slight accumulation of dust come past the bed rail, under the plastic bedrail cap despite obsessively plugging the bedrail holes in the Tundra pre-camper install. Not enough to complain about, but I also get some dust blown in past the barn doors when I use my compressor to blow off the back of the camper after stopping for the day or lunch. So I did this:
It’s 2 120mm cooling fans that are rated at 116 CFM mounted on a 10.4”x7.2x2.4" project box over the inlet for the PPV. I sealed the box around the PPV inlet and bolt holes. I like this company's boxes as they are O ring gasketed and used a smaller one for my electrical switch box previously. On Amazon as:
Zulkit Junction Box ABS Plastic Dustproof Waterproof IP65 Universal Electrical Boxes Project Enclosure​
The box is pretty deep and it easily fits the dacron aquarium filter material I was already using. In the picture, there is also a sheet of MERV 13 over the dust filter that I was testing to see if I could also use it to filter smoke.
I tapped the 10awg wiring to my fridge and ran the power through an on/off switch and added a 3amp fuse. Both fans together draw an amp, and they are powerful enough to pull through both kinds of filters with a decent flow. I plan to not use the MERV 13 filter unless we’re camping and it’s smoky (I have a mild case of asthma) and on a routine basis just use the Dacron dust filter. I believe it will still work well as a passive PPV without turning on the fans, and I plan to just flip the side hatch when stopped and turn the fans on when I’m blowing off the barn doors to counter the blast of air trying to push dust in. Haven’t tested yet, but will be doing so in about a month. Will be happy to post more detail on the parts. etc, but trying to keep this post from being too long.
Since I had some left over MERV13 material, I decided to see if I could put it in the MaxFan. Real easy to do and as long as I don’t inadvertently set the fan to blow out can use it to filter air coming in. Won’t do this, except in a dust storm or smoke conditions if it’s getting too hot or stuffy inside.
gp01
